Page 1 of 4 1 2 3 4
Mopar Commando heads #513009
11/01/09 09:55 AM
11/01/09 09:55 AM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
I saw these in the latest Mancini Flyer and no nothing about them. Any opinons out there about them.
Re: Mopar Commando heads [Re: flatiron] #513010
11/01/09 10:18 AM
11/01/09 10:18 AM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
My friend has a 416 stroker and runs 6.4 in the 1/8 mile....he has large port commando heads
Dan
Re: Mopar Commando heads [Re: Wedgeman] #513011
11/01/09 10:24 AM
11/01/09 10:24 AM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Anything you can Compare them to Eddie's, J heads etc
Re: Mopar Commando heads [Re: flatiron] #513012
11/01/09 11:47 AM
11/01/09 11:47 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
there is two..version..well now actually 3
there is a small 177cc intake runner version
with rocker stands cast in place.
its got killer comb. chambers and with porting can be an ecellent head...more expesive than an assembled eddie though.
then next is the larg port commando...its 188cc intake runner..and has larger bowls. the rocker stand mounts are machined off..so it will need the blocks to set up the rocker system.but will accept long valve combos better
i understand these heads are discontinued so ..the part number now refers to an iron casting...
i dont know if the iron is large or small runner though..
fwiw..
the large port heads can be ported to flow 320cfm..fwiw..
ive seen the small port version..go 290cfm..fwiw
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Mopar Commando heads [Re: cheapstreetdustr] #513013
11/01/09 01:32 PM
11/01/09 01:32 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
The part number I am refering to in the Mancini flyer is MRE 4876765PM
Re: Mopar Commando heads [Re: flatiron] #513014
11/01/09 02:26 PM
11/01/09 02:26 PM
State of Corruption
camdog440 Offline
camdog440  Offline
State of Corruption
How do the Large port Commandos compare to W-2's?
Re: Mopar Commando heads [Re: camdog440] #513015
11/01/09 02:30 PM
11/01/09 02:30 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Maybe RyanJ will chime in and explain, you can go to his web site and see the one's he did for me in the pictures.
Re: Mopar Commando heads [Re: dartman366] #513016
11/01/09 04:29 PM
11/01/09 04:29 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I think the large port in a heavily ported job can be close to a big effort W2, not quite the flow but a better chamber and aluminum, also the LP Commando is way more expensive, thats why they got discoed, no sales so no one wants them right
Re: Mopar Commando heads [Re: flatiron] #513017
11/04/09 03:25 PM
11/04/09 03:25 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
The small port Commando shares the same chamber, exhaust port, intake bowl and short turn.
The difference is the intake runner. The pushrod pinch on the small port is .780" wide compared
to the LP at 1.018". The LP also has had the intrusive boss for the Magnum studs omitted from
their port core, even though it can be ground entirely away on the small port head.
.....Small Port Commando OOTB..........
.100"_____60.8
.200"____107.6
.300"____154.2
.400"____193.3
.500"____218.6
.550"____227.8
.600"____233.4
.650"____237.1*
.700"____239.1*
* slight turbulance
Tested with a MP 2.02" x 5.280" valve NO B/C
Re: Mopar Commando heads [Re: S/ST 3040] #513018
11/04/09 03:32 PM
11/04/09 03:32 PM
S/ST 3040 Offline
S/ST 3040  Offline
Here is the same port with only chamber work.
.100"_____63.5
.200"____125.9
.300"____178.2
.400"____210.6
.500"____225.6
.550"____231.3
.600"____235.9
.650"____237.0
.700"____238.2*
* slight turbulance
Re: Mopar Commando heads [Re: S/ST 3040] #513019
11/04/09 03:42 PM
11/04/09 03:42 PM
S/ST 3040 Offline
S/ST 3040  Offline
OEM entrance.
Re: Mopar Commando heads [Re: S/ST 3040] #513020
11/04/09 03:45 PM
11/04/09 03:45 PM
S/ST 3040 Offline
S/ST 3040  Offline
Novice port match was intentional. Only to get port entrance to
line up with my radius plate for standard SB port window.
Re: Mopar Commando heads [Re: S/ST 3040] #513021
11/04/09 03:52 PM
11/04/09 03:52 PM
S/ST 3040 Offline
S/ST 3040  Offline
Magnum stud boss. (Commandos are from the same castings as the aluminum Magnums)
Re: Mopar Commando heads [Re: S/ST 3040] #513022
11/04/09 03:55 PM
11/04/09 03:55 PM
S/ST 3040 Offline
S/ST 3040  Offline
Top side machined for LA style shaft rocker gear.
Re: Mopar Commando heads [Re: S/ST 3040] #513023
11/04/09 04:03 PM
11/04/09 04:03 PM
S/ST 3040 Offline
S/ST 3040  Offline
For comparison, here is a LP Commando with the same valve.
_________INTAKE_____________Exhaust
.100"____54.7________________60.2
.200"____95.7_______________107.1
.300"___141.9_______________142.8
.400"___191.4_______________161.3
.500"___229.8_______________166.8
.550"___241.5_______________167.2
.600"___252.5_______________168.4
.650"___259.4
.700"___263.6
MP 2.02/1.60 No BC OOTB
Note: Exhaust flow will be the same on the small port
EDIT: added a picture of LP Commando
Re: Mopar Commando heads [Re: S/ST 3040] #513024
11/04/09 04:17 PM
11/04/09 04:17 PM
S/ST 3040 Offline
S/ST 3040  Offline
Here's an Edelbrock RPM #6077 OOTB
..................IN............................EX
.100"_____63.7_________________54.4
.200"____122.0________________111.8
.300"____177.7________________152.0
.400"____218.7________________174.8
.500"____236.0________________186.7
.550"____238.3________________187.3
Re: Mopar Commando heads [Re: S/ST 3040] #513025
11/04/09 04:25 PM
11/04/09 04:25 PM
S/ST 3040 Offline
S/ST 3040  Offline
No valve job or short turn on these yet so, I don't have any final numbers.
I think they have more potential than the Edelbrock heads. They should have
moved the pushrod .250" and used T/A rocker gear.
Re: Mopar Commando heads [Re: S/ST 3040] #513026
11/04/09 04:32 PM
11/04/09 04:32 PM
S/ST 3040 Offline
S/ST 3040  Offline
These will get the pushrods sleeved.
Oh, and every one of the guides are too big......brand new.
Re: Mopar Commando heads [Re: S/ST 3040] #513027
11/04/09 04:55 PM
11/04/09 04:55 PM
i was gonna press fit a dowl in the pushrod bore.
and redrill the pushrod hole with stage 6 rocker offset..
although i may go to w2 offset because these rockers are still being made..
then lay back the pusrod pinch in the window to what ever moved the best air.
fwiw.
[image][/image]
Re: Mopar Commando heads [Re: cheapstreetdustr] #513028
11/04/09 05:00 PM
11/04/09 05:00 PM
S/ST 3040 Offline
S/ST 3040  Offline
The pivot length is too long on any W-2 rocker I've tried.
Harland Sharp still makes the T/A set-up.
Page 1 of 4 1 2 3 4
