procharger #512508
10/31/09 05:48 PM
10/31/09 05:48 PM
wisconsin
jp66charger Offline OP
wisconsin
I think I have hit the limits on what I want to do with my Charger and am now considering a different direction. I have a very nice 71 dart mini tubbed and roller. Thinking maybe 511 lowdeck with pro charger and indy heads. Problem is I don't know a thing about them. How does it work? Do you have to keep a water tank full all the time? Can a stock block half filled stand up to this combo? Cost??? What compression to build motor? Any advice would be helpfull. I am a year away from starting an engine combo, but already dreaming. Thanks, JP
Re: procharger [Re: jp66charger] #512509
10/31/09 06:22 PM
10/31/09 06:22 PM
Greenville, WI
Big B Offline
Big B  Offline
Greenville, WI
Steve Morris at neweraracecraft would be the person to email
With Pro-charger questions.
SMRE would be good too. That's where Steve used to work
Before heading out on his own.
Re: procharger [Re: jp66charger] #512510
10/31/09 08:11 PM
10/31/09 08:11 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
some of the people here have some help for you to figure out what you want.will it be street or race?
Re: procharger [Re: blownzoom440] #512511
10/31/09 08:13 PM
10/31/09 08:13 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
hmmmm i wish i new something.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: procharger [Re: bigtimeauto] #512512
10/31/09 10:10 PM
10/31/09 10:10 PM
wisconsin
wisconsin
Plan for this car is light weight and race only. Already have one 4260# street strip car, so this one will be under 3000# and shooting for mid 9's. Found a couple articles which helped answer some ?'s. Looks like factory block is out but I don't know that for sure and cannot find a price for one of these kits. Thanks, JP
Re: procharger [Re: jp66charger] #512513
10/31/09 10:14 PM
10/31/09 10:14 PM
wisconsin
wisconsin
bigtimeauto!!! That looks amazing. Also like the shoe polish on the windshield. What combo does it take to write a number like that?
Re: procharger [Re: jp66charger] #512514
10/31/09 10:15 PM
10/31/09 10:15 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Under 3000 and mid 9's you can do NA about 800hp crankshaft.
Re: procharger [Re: jp66charger] #512515
10/31/09 10:16 PM
10/31/09 10:16 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
be prepared to spend what seems like endless amounts of money. They work though
Re: procharger [Re: jp66charger] #512516
10/31/09 10:17 PM
10/31/09 10:17 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
540, 23lbs boost,blow thru, no intercooler and a lot of brake pedal.
Re: procharger [Re: prochargedhemi] #512517
10/31/09 10:18 PM
10/31/09 10:18 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
so true
Re: procharger [Re: jp66charger] #512518
10/31/09 10:20 PM
10/31/09 10:20 PM
ELYRIA,OH
ELYRIA,OH
bigtimeauto!!! What combo does it take to write a number like that?
9'0s at 3,000lbs is not that hard.
Re: procharger [Re: prochargedhemi] #512519
10/31/09 10:21 PM
10/31/09 10:21 PM
wisconsin
wisconsin
Can it be done for 6k? Aftermarket block required? Where to start compression? Thanks.
Re: procharger [Re: jp66charger] #512520
10/31/09 10:25 PM
10/31/09 10:25 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Ahhhh., nope
Re: procharger [Re: jp66charger] #512521
10/31/09 10:26 PM
10/31/09 10:26 PM
Temperance, MI
P
P
Temperance, MI
depending on what you wanna do a stock block could be used. do a search for "procharged 440" and look at the build engine masters did a few years back. Now in reality that build pulled the pin on the grenade and most parts were at or above what they could handle. I think with a few upgrades you could make that power and more reliably. If you keep a good eye on the tune and don't get greedy (really leanin on it) i beleive stuff will last alot longer
Re: procharger [Re: prochargedhemi] #512522
10/31/09 10:50 PM
10/31/09 10:50 PM
wisconsin
wisconsin
Thanks prochargedhemi. I'll do a little more research, but can anyone give me an idea as to cost? I know what killpatrick will charge me for turn key 800 and 1000 hp(N/A). No clue what a procharger costs. Not scared to spend money where it counts, but need a place to start planning.
Re: procharger [Re: jp66charger] #512523
10/31/09 10:54 PM
10/31/09 10:54 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
No matter what you build it needs to have a good foundation. A procharged engine or a 1000hp NA will cost the same money then you have to add the price of the blower stuff on top of it. Your goal is easily obtainable NA
Re: procharger [Re: jp66charger] #512524
10/31/09 10:54 PM
10/31/09 10:54 PM
ELYRIA,OH
ELYRIA,OH
the SMRE site has kits listed with HP #'s
then you have the engine to build.
Re: procharger [Re: prochargedhemi] #512525
10/31/09 10:58 PM
10/31/09 10:58 PM
OHIO,CIRCLEVILLE
68DARTTURBO Offline
68DARTTURBO  Offline
OHIO,CIRCLEVILLE
I am a PRO CHARGER DEALER and build many combos a small block w/20 lbs of boost will put 3000 lbs on a blow thru carb 8.50s all day!!!!
good small block $9,500
F2 w/inner cooler $8,900
good blow thru carb $1,100
8.50 time ticket PRICELESS!!!
Re: procharger [Re: 68DARTTURBO] #512526
11/01/09 12:07 AM
11/01/09 12:07 AM
OHIO,CIRCLEVILLE
68DARTTURBO Offline
68DARTTURBO  Offline
OHIO,CIRCLEVILLE
Is SM still with RE or is steve somewere else
Re: procharger [Re: 68DARTTURBO] #512527
11/01/09 12:17 AM
11/01/09 12:17 AM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
http://www.neweraracecraft.com/
Steve Morris's new business.
Mike Gray
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
