Re: Possible nightmare problem before engine installation!
[Re: stumpy]
#512367
10/31/09 05:00 PM
10/31/09 05:00 PM
Challenger 1
Cincinnati, Ohio
Bump stops should be removed and the lower control arms pulled down as far as possible with the adjusting bolts backed out all the way to get the T bars prelaoded.
[Re: wh23g3g]
#512372
10/31/09 11:37 PM
10/31/09 11:37 PM
Posts: 4,872 connecticut
pnypwr
connecticut
front end parts should be torqued with the weight on the vehicle!
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
[Re: wh23g3g]
#512373
11/02/09 05:30 AM
11/02/09 05:30 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Are you trying to install them with out separating one of the ball joints or disconnecting the upper control arm at the bushings, so the lower control arm can hang down lower?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: wh23g3g]
#512375
11/02/09 08:18 PM
11/02/09 08:18 PM
jbc426
West Coast, USA
No I don't need to separate them....
That's why you're having such a hard time. If I hadn't left the lower control arm's main pivot shaft and nut loose and pulled the upper control arm's eccentric bolts so the control arm could hang down and wiggle around a bit, mine would have been nearly impossible to put back in too.
I had the same issue, but didn't want to force it. Once I saw that it was binding, I stopped and loosened up the points mentioned, and mine slid right in with a couple of light taps.
[Re: wh23g3g]
#512378
11/03/09 04:18 PM
11/03/09 04:18 PM
Posts: 30 Oakbank, Manitoba, Canada
64 Savoy
I was checking over everything on the front end getting my torsion bars base adjusted before I attempt to install my 400/727 in my 73 Charger. I installed the new front urethane suspension, joints, tie rods, about a year ago. Everything was bead blasted and painted a normal coat of black epoxy, but not the thick stuff just rattle can stuff. I remember the passenger side torsion bar went in real easy and the drivers side was the one that gave me trouble. They've been installed about a year ago with the car still up in the air. Remember I was having trouble turning the adjuster screw on the torsion bars. Well I just went to adjust the driver's side and it was nice and easy and touched the anchor pivot easily. But on this passenger side torsion bar the anchor is all the way up so that's why the adjustment screw was always wobbling and hard to turn. How do I get the anchor to loosen and drop back down so I can adjust it? I loosened up the pivot shaft nut but it didn't change. I tried to knock the anchor pivot back down from the top but it won't move. Am I going to have to remove the bar again? What do you think happened? I guess this will keep me from installing the motor for awhile.
Try loosening the strut rods. It made a big differnce for me.
