Prepping Rusty Engine for Repainting #512301
10/31/09 12:15 PM
10/31/09 12:15 PM
Detroit, MI
FC7AARcuda Offline OP
Detroit, MI
I have 340 engine I rebuilt several years ago. It runs great but the frame on the car rusted out so the car has sat mostly outside for the last 5+ years. The engine has started to rust in spots. I want to clean it up and put in another body I bought. I don't want to blast the engine block and risk getting anything inside. Whats the best way to clean up the assembled engine and prevent (at least slow down) the rust from coming back? The body its going into will be kept inside. Thanks.
Re: Prepping Rusty Engine for Repainting [Re: FC7AARcuda] #512302
10/31/09 12:19 PM
10/31/09 12:19 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I'd block all the passages and wire brush it. Put a wire wheel on a drill and go to town.
Re: Prepping Rusty Engine for Repainting [Re: burdar] #512303
10/31/09 01:01 PM
10/31/09 01:01 PM
Maryland
brianz426 Offline
brianz426  Offline
Maryland
Maybe also some Naval Jelly on the tough spots.
Re: Prepping Rusty Engine for Repainting [Re: brianz426] #512304
10/31/09 01:19 PM
10/31/09 01:19 PM
waukon iowa
1hot68 Offline
1hot68  Offline
waukon iowa
.....and if you have access to a neddle scaler,they work well in tight corners and such.
Re: Prepping Rusty Engine for Repainting [Re: 1hot68] #512305
10/31/09 02:47 PM
10/31/09 02:47 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
A needle scaler will work but it will also scar up the cast iron surface while it's removing rust, use them with caution on cast iron if final cosmetics are important to you.
Re: Prepping Rusty Engine for Repainting [Re: ScottSmith_Harms] #512306
10/31/09 03:44 PM
10/31/09 03:44 PM
scratchnfotraction Offline
I scrub them down with oven cleaner soak,rinse,dry with air hose,spary it down good with brake clean,air dry,paunt it with duplicoler hemi orange
Re: Prepping Rusty Engine for Repainting [Re: scratchnfotraction] #512307
10/31/09 03:56 PM
10/31/09 03:56 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
You can use wire end brushes and metal prep with gloves, after using above, spray down with brake clean and use self etching primer before spraying any paint.
logan426
Re: Prepping Rusty Engine for Repainting [Re: MLR426] #512308
11/01/09 12:58 AM
11/01/09 12:58 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
logan426
Who makes etching primer?
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Prepping Rusty Engine for Repainting [Re: joedust451] #512309
11/01/09 08:26 AM
11/01/09 08:26 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
you can buy SEM etching primer in cans at most paint jobbers.
