Piston to Valve Clearence Question #510707
10/29/09 01:44 PM
10/29/09 01:44 PM
Nanuet, NY
3
383BeepBeep Offline OP
Nanuet, NY
I know the rule of thumb is .080" for intake on a steel rod engine. Here is my problem/question. I took the 452 heads off of my 383 and put on a set of eddy 84cc heads. Did a valve/piston check with checking springs and dial indicator. Exhaust is fine. Intake is terrible at 5* ATDC to 10* ATDC. Now the way I see it the intake valve is chasing the piston, and shouldn't be a problem. Should I change my way of thinking or button her up? What do you guys think?
1969 Plymouth Roadrunner - 383- 4 Speed - Dana 60 4:10
Re: Piston to Valve Clearence Question [Re: 383BeepBeep] #510708
10/29/09 02:07 PM
10/29/09 02:07 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
How did you check it? Did you install the cam and time it correctly, then do the clay on the top of the piston and rotate the crank? Because cam timing greatly affects p/v clearance.
Re: Piston to Valve Clearence Question [Re: DaytonaTurbo] #510709
10/29/09 02:27 PM
10/29/09 02:27 PM
Nanuet, NY
3
Nanuet, NY
When the engine was first built the cam was installed straight up. I would prefer not to retard cam to make this work. All measurements are being done with checking springs and a dial indicator. The worst of the measurements is .010" @ 6* ATDC
Re: Piston to Valve Clearence Question [Re: 383BeepBeep] #510710
10/29/09 02:32 PM
10/29/09 02:32 PM
sg66mopar Offline
sg66mopar  Offline
I you're running a roller cam you should check with the springs you'll run. Heavy roller cam springs can cause a lot of deflection in the valve train and your current numbers could go out the window.
Re: Piston to Valve Clearence Question [Re: 383BeepBeep] #510711
10/29/09 03:02 PM
10/29/09 03:02 PM
With .080" being the mininmum at any point in the cycle, .010" is not acceptable. Not sure the best way out whether flycutting (enough cutting might change balance too far) A thicker gasket would cost CR (& possibly your quench). Smaller cam. When you solve it if your cam gear has (3) keyways I'd suggest checking the VP clearance in all three positions so later on if you experiment w cam timing the PV clearance will already be dealt with. I prefer light springs and a dial indicator rather than light springs and clay (less mess/more accurate & a direct reading) & check the radial clearance between the perimeter of the valve and the eyebrow in addition to the depth. Good luck & holler back with how it turns out.
Re: Piston to Valve Clearence Question [Re: RapidRobert] #510712
10/29/09 03:23 PM
10/29/09 03:23 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Your not using clay?
I would check the degree on the cam. Is there no valve notches on your pistons??
Re: Piston to Valve Clearence Question [Re: Dodgem] #510713
10/29/09 03:33 PM
10/29/09 03:33 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
The way he is doing it much more accurate than clay.
Re: Piston to Valve Clearence Question [Re: MoparforLife] #510714
10/29/09 04:13 PM
10/29/09 04:13 PM
Nanuet, NY
3
Nanuet, NY
Thanks guys for replying. As for the pistons, they are 2315's, which do not have reliefs in them. And this is a zero deck engine. I have decided to not use the eddy's right now. The 452's are going back on.
