Re: 1969 Roadrunner Blower motor??
[Re: tims69belvedere]
#510509
11/08/09 11:08 AM
11/08/09 11:08 AM
Posts: 836 lancaster, new york
macmic87
lancaster, new york
you can probably find a correct fitting motor through grainger or O'Reilly auto parts but you won't get the right wire end and it won't have the hole for the cooling tube.
if the wires reach on the new motor you have to the fan speed resistor after ligning up the cooling tube, i would use the one you have. once the heater box is installed you and no one else will see it again.
