Re: Gapless rings
[Re: 68post]
#510420
10/29/09 10:03 AM
10/29/09 10:03 AM
Posts: 2,172 Ohio
theclutcher
Ohio
Ive used the gapless seconds. Very happy with them. Either people like them or they dont. Can tell you after a many yrs, albeit not that many miles, street and track, less than 2% leakdown on one hole, rest were less than that. Built that back in '85, still together, waiting next project. One of those builds that gave more than expected. People say static leakdown means little, cant figure that one as its a good indicator for race teams. Total Seal, I'm sold on them.
Re: Gapless rings
[Re: theclutcher]
#510421
10/29/09 10:34 AM
10/29/09 10:34 AM
Posts: 8,165 Left Coast
BobR
Left Coast
Leakdown on a static engine is meaningless. Power is what counts and on every single application that I have seen a gapless ring-especially gapless second ring- was no better and many times inferior to a standard ring pack. We actually tried some on our blown motor. DIDN'T WORK AT ALL.
Re: Gapless rings
[Re: BobR]
#510422
10/29/09 11:09 AM
10/29/09 11:09 AM
Posts: 1,752 detroit area
moderncylinder
detroit area
it got irritating to me this year telling people that my ring seal in my hemi sucked,, they would all ask well,, what does it leakdown?? like that meant something... leakdown will tell you if a valve is bent or seat is beat out,, blown head gasket,, moly on ring flaked,, piston broke,,,
as far as ring seal once the engine is running,, leakdown means nothing
a pro stock guy i know used gapless rings,, just switched to a single gapped ring and picked up 20hp,, by single i mean one top ring,,, where as the gapless is two rings,, it had a 2nd ring in both applications
ive messed around with 2nd ring gap and seen nothing but had piston issues,, i need to readdress if more 2nd gap helps seal,, i know a tighter gapped 2nd ring is worth no power, just leaks down better. ive gapped 2nd rings at .050 and .012 seen no difference
Re: Gapless rings
[Re: theclutcher]
#510428
11/26/09 05:02 PM
11/26/09 05:02 PM
BobR
Left Coast
Leakdown numbers are meaningless. We actually tried a gapless top ring on our Procharged deal. Leaked down real good but it didn't make any power and the ring seal went away real quickly. It still leaked down less than 3% but our crankcase vacuum numbers went positive after only 5 or 6 runs losing 2-3 pounds per run. Like was said, there are applications that may like the gapless setup but I wouldn't use them on my lawnmower after what I saw with our venture.
Re: Gapless rings
[Re: BobR]
#510429
11/26/09 06:06 PM
11/26/09 06:06 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I just got my Total Seal rings in yesterday.Advanced Profiling Steel rings,Maxseal gapless top ring,Napier style 2nd ring.
There is a lot of people on here that really know this stuff so I have a question. Does having your pistons coated help? Or maybe it should be is it worth the money in a Race-Engine?
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
Re: Gapless rings
[Re: Mopar_Rich]
#510431
11/26/09 06:29 PM
11/26/09 06:29 PM
Posts: 1,200 UK
602heavy
UK
How many times have you pulled an engine down to find all rings have moved round the cylinder alingning the gaps? , every time i pull the pistons i find the two part gapless ring along with the other rings have moved around & ring gaps have alined themselves , plus the fact the rail part of the gapless ring (bottom ring) has a hard job tranfering heat into the cylinder wall , plus the fact there no different in thickness than an oil rail. I ran the gapless 2nds on an N20 motor , did'nt wanna take a chance using a gapless top bearing in mind any heat or detonation destroying the thin rail that makes up the gapless ring. I would use the the Total Seal AP top ring along with a Napier 2nd for NA motor that's gonna see any power.
Re: Gapless rings
[Re: 602heavy]
#510432
11/27/09 12:44 AM
11/27/09 12:44 AM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
Well... I see several different opinions of course... The leakdown argument----i really dont get that. SO--heres what my leakdown showed last spring : 20-34% leakdown . some cylinders were 34% !! so...leakdown believers : i need to re-ring.I agree . and leakdown doubters = im totally fine (i find that had to believe)
Re: Gapless rings
[Re: 493_DART]
#510433
11/27/09 11:43 AM
11/27/09 11:43 AM
BradH
Not sure what I can add other than I have the TS "gapless" top rings in my Challenger's engine. I built it myself and it was my decision to run 'em, regardless of the "leakdown debate" that always comes up. The previous incarnation of this engine was built by someone else using Child & Albert's Z-gap "gapless" 2nd ring. I can say after about 4000 miles of street & strip use that the engine was showing leakdown #s in the 4-5% range for all cylinders, other than the two that were experiencging valve sealing issues. After doing some research on my own, I decided to stick w/ a "gapless" design, only switch to the top-ring approach. I wish I could give some hard facts re: either before / after results between a traditional ring design and these and what I'm using now, but I can't. The comparisons I've seen described here or elsewhere have never been conclusive IMO and weren't necessarily what I thought were applicable to my application. As far as the "leakdown doesn't mean anything" perspective... I'll have to fall back on the late Smokey Yunick's position that an engine showing higher than xx% of leakdown is an indication of sealing issues. Maybe the test itself is flawed, but if the before #s are that much lower than the after #s, it's got to be showing "something" isn't right.
Re: Gapless rings
[Re: 493_DART]
#510434
11/27/09 11:45 AM
11/27/09 11:45 AM
BobR
Left Coast
The best way to keep track of dynamic engine seal(rings) is by using a vacuum pump and a gauge to moniter the vacuum in the crankcase. If the vacuum begins to decrease from the new build standard you can tell that the rings are losing seal.
