Why do some AVS carbs have a bowl vent valve? #510022
10/28/09 05:03 PM
10/28/09 05:03 PM
Seattle, WA
3
375inStroke Offline OP
Special needs person
3
Seattle, WA
Some AVS carburetors have a hole on the top of the float bowl that closes when the throttle is closed. Why? Why do some applications not have it?
Re: Why do some AVS carbs have a bowl vent valve? [Re: 375inStroke] #510023
10/28/09 05:06 PM
10/28/09 05:06 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
it's a feature that appeared on the later emissions carbs.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Why do some AVS carbs have a bowl vent valve? [Re: HemiRick] #510024
10/28/09 05:30 PM
10/28/09 05:30 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Are you talking about the rubber flap that overs up the hole in the top when the throttle is applied?? My original AFB on my 67 440 has this feature also....4327S Carter.....
Re: Why do some AVS carbs have a bowl vent valve? [Re: minivan] #510025
10/28/09 06:06 PM
10/28/09 06:06 PM
Seattle, WA
3
3
Seattle, WA
Yes. It's connected to the accelerator pump linkage.
Re: Why do some AVS carbs have a bowl vent valve? [Re: 375inStroke] #510026
10/28/09 06:14 PM
10/28/09 06:14 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
It's called a bowl vent and it opens at idle so pressure does not build up in bowl and push fuel out into carb which would cause a rich/rough idle.
Re: Why do some AVS carbs have a bowl vent valve? [Re: Ply72rr] #510027
10/28/09 06:23 PM
10/28/09 06:23 PM
Mass
charge70 Offline
charge70  Offline
Mass
The AVS carbs that the bowl vent near the acc pump are for non-ecs cars.The carbs that don't have the bowl vent on the acc side have a nipple on the r/h side of the carb in the top half near the choke linkage,a hose runs from that nipple to the crankcase breather on the r/s valve cover.This style carb is for ecs cars that have a "sealed" evap system. John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Why do some AVS carbs have a bowl vent valve? [Re: 375inStroke] #510028
10/28/09 10:17 PM
10/28/09 10:17 PM
when gov't emission regs really started to get tight in '68 they no longer allowed gas fumes to be vented directly to the atmosphere. Not sure why it has to be open at off idle (either to the atmosphere or to a charcoal canister)
Re: Why do some AVS carbs have a bowl vent valve? [Re: RapidRobert] #510029
10/29/09 12:37 AM
10/29/09 12:37 AM
Seattle, WA
3
3
Seattle, WA
If it wasn't open to the atmosphere, once the fuel level in the bowls dropped under acceleration, it would create a lower pressure in the float bowl, preventing fuel from flowing out the discharge nozzles.
Re: Why do some AVS carbs have a bowl vent valve? [Re: 375inStroke] #510030
10/29/09 12:21 PM
10/29/09 12:21 PM
Shoreline, Washington
72roadrunnergtx Offline
The valve closes at any throttle position other than idle. The bowls are vented primarily through the air horn to insure pressures above the fuel in the bowls equals the pressure above the venturies, regardless of any potential air flow restrictions (i.e. dirty air filters). The idle bowl vent intended purpose is to release evaporating fuel vapors outside the air cleaner under hot idle & heat soak engine off conditions. Without the idle vent valve, fuel vapor collects in the air filter housing making for hard hot starts and unstable over rich hot idle.
As stated, for E.C.S. the idle bowl vent valve was enclosed and fitted with a hose nipple to collect and later reuse these vapors.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
