Most Cubes Out of a 426 Hemi?
#509727
10/28/09 09:32 AM
10/28/09 09:32 AM
Posts: 775 San Antonio, Tx
bulletpruf
San Antonio, Tx
Fellas -
Wondering how many cubes I can get out of my 426 hemi. It's an over the counter Mopar block; likely cast in 2006 or so. May go through it this winter and thinking about a new rotating assembly.
Thanks in advance for any info,
Scott
Please Check Out My YouTube Channel for Vintage Musclecar and Truck Rescues and Builds -- https://www.youtube.com/@THEBULLETPROOFGARAGE/videos
Re: Most Cubes Out of a 426 Hemi?
[Re: LikarockCrusher]
#509734
10/28/09 10:14 AM
10/28/09 10:14 AM
bulletpruf
San Antonio, Tx
Ok, I checked Indy's site. 605" or so sounds good to me. How much work is involved fitting a 4.5 or 4.75 crank in the stock block? Grinding needed for rod bolt clearance?
I'm assuming that the block should take a 4.500 bore, too, but are most blocks good for this or is this really dependent on the sonic check? Does this leave me any room for a rebuild/overbore?
Thanks!
Scott
[Re: bulletpruf]
#509735
10/28/09 10:21 AM
10/28/09 10:21 AM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
It depends on which block you have. There are 2 versions of the hemi blocks...one that can go to 4.5" bore (megablock) and another that really shouldn't go any further than 4.31" (replacement block). You still need to have it sonic checked to see how thick it is. CHIP
#509739
10/28/09 10:44 AM
10/28/09 10:44 AM
bulletpruf
San Antonio, Tx
E mailed Indy. They didn't answer on machine work, but said they thought that I had a stock replacement block with a max bore of 4.375 (have to sonic check) with max cubes at 540.
Scott
[Re: bulletpruf]
#509741
10/28/09 01:40 PM
10/28/09 01:40 PM
Posts: 4,848 Memphis
HemiRick
Memphis
To put more than 4.15 worth of stroke in it generally means the stock oil pickup has to go, no room.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#509742
10/28/09 02:03 PM
10/28/09 02:03 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
"Which weighs more, a pound of feathers or a pound of stones"
That's easy. Feathers obviously weigh less than stones. Next question please.
[Re: Snoopy]
#509744
10/28/09 04:14 PM
10/28/09 04:14 PM
Posts: 75,139 A Banana Republic near you.
JohnRR
Wasn't there a block with a raised cam for large stroke engines?
yes and he would need it to go as big on the stroke that he wants .
on the block he has , more than likely a water block , should have had a yellow sticker on the bellhousing flange telling you max overbore , mine i am pretty sure says 4,340 , maybe it's 4.310 I'd haveto drag it out to look .
I wouldn't max bore it , then it's got no lives left .
[Re: bulletpruf]
#509745
10/29/09 07:46 PM
10/29/09 07:46 PM
Posts: 576 Somewhere Over the Hill
Mr. Dodge
I have 588 cid Hemi in My R/T ![](/ubbthreads/images/graemlins/drive.gif) Have you seen the movie Up in Smoke that's the R/T on the street
"The advantage of being armed the Americans possess over the people of all other nations,which are carried as far as the public resources will bear, the governments are afraid to trust the people with arms."(James Madison)
69 Hemi Coronet R/T
70 456 Dart Swinger
