Lexan side windows like the old Super Stock Mopars #509138
10/27/09 06:51 PM
10/27/09 06:51 PM
Auburn, Indiana
The Duster Offline OP
Auburn, Indiana
Does anyone make side window kits that use seat belts to raise and lower the side windows like the old SS/ did?
Re: Lexan side windows like the old Super Stock Mopars [Re: The Duster] #509139
10/27/09 08:22 PM
10/27/09 08:22 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I did my own for my 63 Polara. I riveted the strap to the bottom of the Lexan. I used Velcro at the top and bottom of the door panels to hold the strap when the window was up or down. The only problem I had was that self adhesive Velcro came loose from the door panel. I ended up sewing the Velcro to the strap and riveting the other side of the Velcro to the door panel. I bought the supplies at a Army/Navy surplus store.
Doug
Re: Lexan side windows like the old Super Stock Mopars [Re: The Duster] #509140
10/27/09 08:38 PM
10/27/09 08:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sorry I cant help you...other than make your own...
But welcome to the jungle
Re: Lexan side windows like the old Super Stock Mopars [Re: dvw] #509141
10/27/09 08:38 PM
10/27/09 08:38 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I should add Fred is correct. I cut the piece the same dimensions as the stock glass. Except the bottom where I shortened it up a bit. My 63 was a hardtop as well so I siliconed the chrome run channel to the Lexan.I used 3/16" as I remember. My new project is a 64 Belvedere postcar. I'm only using 1/8" thick. I'm going to glue the edges with a 2nd thickness where it sits in the run channel. That way it won't rattle around in the channel. I may glue a piece across the top as well. That will stiffen it as well as making it look stock when its rolled down. It will be hidden in the channel when it's rolled up.
Doug
Re: Lexan side windows like the old Super Stock Mopars [Re: dvw] #509142
10/27/09 08:42 PM
10/27/09 08:42 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Welcome to Moparts.
Re: Lexan side windows like the old Super Stock Mopars [Re: The Duster] #509143
10/28/09 04:15 PM
10/28/09 04:15 PM
Auburn, Indiana
Auburn, Indiana
Thanks for the warm welcome and advice guys. I'm sure I'll have more questions as this is my first strip only build.
Re: Lexan side windows like the old Super Stock Mopars [Re: The Duster] #509144
10/28/09 04:21 PM
10/28/09 04:21 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
Welcome aboard...I have a little experience with early A's. Here's my Dads 64 with a smogger 440 on board.Power brakes and still has all of it's fender liners.Looks totally stock under the hood(cast iron manifolds)...good luck
