Re: 451 High RPM Breakup / Miss
[Re: ChrisDavis]
#509006
10/27/09 07:24 PM
10/27/09 07:24 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
Chris, i would suspect fuel, if its dropping below 5 lbs. that could cause a problem, on a stock engine you prob. wouldn't notice anything, but a race engine @ high RPMs will not like this, i had my pressure set @ 7 lbs. on my 451, from beggining to the end of the 1/4 mile it stayed "rock" steady at 7 lbs., you need to fix this problem, i'll bet it runs great after that.
[Re: RapidRobert]
#509008
10/29/09 06:56 PM
10/29/09 06:56 PM
Posts: 75 Illinois
ChrisDavis
Illinois
OK, I ran a test using an old distributor cap with a hole drilled in it and a timing light. With the vacuum advance disconnected the rotor phasing was absolutely perfect. Connecting the vacuum advance put it off by about the width of the rotor contact tip, but of course that goes away under wide open throttle. I found that the distributor is installed 180* off. #1 is at the bottom not the top. I don’t see this as a problem as long as the rotor lines up, the timing is correct and the plug wires are landed appropriately. I tried free revving the engine in neutral and found that a slight miss starts at about 4300 RPM and gets worse the higher you go. I didn’t rev past 5000 RPM though. I realize that free revving is a poor test of anything and the miss I felt may just be because there is no load on the engine. Under a load it does not miss at all and pulls very hard then I hit that non existent rev limiter and it flat stops gaining RPM. I would think that fuel pressure would not be an issue when free revving since there is no engine load and no real fuel demand. I am pulling my hair out. Does anyone have any other ideas?
[Re: ChrisDavis]
#509012
10/29/09 09:39 PM
10/29/09 09:39 PM
RapidRobert
reluctor gap (.005") EDIT long shot, might cut another hole in the junk cap in the side & check the clearance between the rotor blade tip & the terminal on the underside of the cap. Might sub in another set of plugs
[Re: RapidRobert]
#509013
10/29/09 10:04 PM
10/29/09 10:04 PM
Posts: 7,506 Az
Crizila
Az
Don't know what you are running for compression, but you might try closing the plug gap to .025 - .030 just to see if that helps. If it does, you don't have enough secondary voltage to light the plugs at higher cylinder pressures. Might wanna make sure you are running the correct voltage to the ignition primary side also. Assume you ohm checked the wires ( should be under 2000 ohms ) and they are good?
Fastest 300
[Re: ChrisDavis]
#509018
10/30/09 10:58 AM
10/30/09 10:58 AM
joedust451
super gas
super gas
Branson, Mo.
Chris, make sure the ECU is grounded "good", i would run a spare ground wire just for it, it still sounds like an ignition problem, but my next guess would be the valve springs, seeing it still breaks up standing still, i'll say its not the fuel now, unless its falling to 0.
[Re: joedust451]
#509020
10/30/09 01:11 PM
10/30/09 01:11 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
You sure your getting the pre load right?? seen many push down till they fell resistance but that can be .100 down if the lifters did not load completely or pumps down a bit as you turn it over. The visually method making sure the plunger is coming up to the wire stop is the best way! Here is what I would try. back all the adjusters off 1 turn if they are still quiet go 1/2 turn at a time after that till it ticks then go back 1/2 turn. NEXT This is time consuming but after you may want to do one at a time. (or pull the intake! LOL))) It sure sounds to me like pump up valve float??? Hard to hear good from hear though!!!
[Re: Dodgem]
#509022
10/30/09 05:48 PM
10/30/09 05:48 PM
Posts: 75 Illinois
ChrisDavis
Illinois
More great ideas. I will try them all.
joedust451, I believe the ECU is well grounded. At least I know the bolts are tight and it is chrome plated, not painted, so it should be. I’ll check for voltage between it’s housing and the battery’s negative post while the engine is running just to be sure the ground is making it all the way there. I’ll also check resistance between the same two points with the engine off.
Alyerpal2, I could throw another quart of oil in it, but I have watched the oil pressure gauge and it sits rock solid at 60 lbs or so regardless of RPM.
Dodgem, You have given me an idea. Maybe when I test this weekend I will record what it sounds like and post it here. Valves are where I am heading next. I just spoke with the machine shop that did the heads and they suggested I set the lifters at 0 lash hot. They believe this would eliminate any possible pump up issues. As far as method, I think I will back them all off until they are loose and then wait an hour or so for them to bleed up, if they will? I normally roll the pushrod between my fingers while tightening the adjuster until I feel resistance. That should be 0 lash. These were set by putting #1 at TDC and then adjusting the #2 intake and #8 exhaust, etc. When I adjust them this time I think I will use the #1 intake at full lift then adjust the #6 intake method.
Dodgem, I do not use the composite brass fuel filters you are referring to.
