Page 2 of 4 1 2 3 4
Re: W9 or P7 ? [Re: moparacer] #50892
12/26/07 08:43 PM
12/26/07 08:43 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
There is several variations, so what you are describing is a definite possibility with the P7 stuff. I have heard of some weird and wonderful ports with these heads.
AL....
Alan Jones
Re: W9 or P7 ? [Re: LA360] #50893
12/27/07 12:06 AM
12/27/07 12:06 AM
Dillsburg, PA
mrsmallblock Offline
Dillsburg, PA
the 500 intake is the same as the 420. the whole number is 5007420.
howard
mrsmallblock
Re: W9 or P7 ? [Re: LA360] #50894
12/27/07 12:07 AM
12/27/07 12:07 AM
Of the ones on ebay, what should we NOT buy. Any signs to look for??
Re: W9 or P7 ? #50895
12/27/07 12:35 AM
12/27/07 12:35 AM
LA360 Offline
LA360  Offline
I bought all my stuff through Rick Liuzzo, who has a Ebay site, and the site listed in my Sig.
http://stores.ebay.com.au/Hardcore-Mopar-Race-Parts_W0QQssPageNameZstrkQ3amefsQ3amesstQQtZkm
I think most sellers use a generic pic, so I would speak to someone like Rick who has some experience with these engines. He'd know which heads to stay clear of.
AL...
Alan Jones
Re: W9 or P7 ? [Re: LA360] #50896
12/27/07 01:42 AM
12/27/07 01:42 AM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
here is a picx.
Re: W9 or P7 ? [Re: SB449VALIANT] #50897
12/27/07 10:16 AM
12/27/07 10:16 AM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
How much difference is there between the 420 & 598? Is it worth getting a 420 to modify & adapt a Dominator vs modifying a 598?
Re: W9 or P7 ? [Re: STEFF] #50898
12/27/07 03:42 PM
12/27/07 03:42 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I meant to refer to that intake as 420 not 500. They claim there is a tremendous difference due to there is more material to do more work to the intake. I have heard that out of the box they are better but I don't know the 420 was the first I ever ran out of the box if you want to call converting to dominater flange out of the box. My 772 is ported to the extremes as it was run on a 468 Nitrous engine. I really need to work on the 420 but like I said why make HP when the combo does not perform in the car. Fix the problem then find more HP. I am just waiting to go to the track as I think I have a good idea where the problem is.
Leon
Re: W9 or P7 ? [Re: Leon441] #50899
12/27/07 06:08 PM
12/27/07 06:08 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
598
Re: W9 or P7 ? [Re: RyanJ] #50900
12/27/07 06:09 PM
12/27/07 06:09 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
598AB
Re: W9 or P7 ? [Re: RyanJ] #50901
12/27/07 06:10 PM
12/27/07 06:10 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
420
Re: W9 or P7 ? [Re: RyanJ] #50902
12/27/07 06:12 PM
12/27/07 06:12 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Magnesium Prototype.....
Re: W9 or P7 ? [Re: RyanJ] #50903
12/27/07 06:13 PM
12/27/07 06:13 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Twister
Re: W9 or P7 ? [Re: RyanJ] #50904
12/27/07 06:16 PM
12/27/07 06:16 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
772
Re: W9 or P7 ? [Re: RyanJ] #50905
12/27/07 06:17 PM
12/27/07 06:17 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
772 converted to 4500
Re: W9 or P7 ? [Re: RyanJ] #50906
12/28/07 09:26 AM
12/28/07 09:26 AM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Ryan do you have a picture of the arrington intake by chance you could post thank you
Re: W9 or P7 ? [Re: scottb] #50907
12/28/07 06:46 PM
12/28/07 06:46 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
I was going to try to take some at shop today, but we had steady stream of visitors all day & did'nt get around to it.
Re: W9 or P7 ? [Re: STEFF] #50908
12/29/07 12:39 PM
12/29/07 12:39 PM
Carbondale PA
Domino1609 Offline
Domino1609  Offline
Carbondale PA
The only reason I ask is a buddy of mine, using the 15 degree Chevy CFE's on a 427" motor with a BES modified W789 intake & dominator made about 975hp. The motor went 8.49 @3000lbs. I'm kinda' suprised that 900 would be the cap for a w8 or 9 motor with a single 4, if the heads are equally as good. Apperently Bishoff really knows how to make that intake work & yes this motor was set on kill......valve spring eater, high maintainence etc...
I am not making this post to start a war but I will say this. A 15^ GM head and a 15^ Mopar head both done by CFE, taking into consideration the fact that both would be built for the same class, the same bore size the same everything. All things given they are almost the same port, now remember I am talking about the generally available stuff not the special PN Mopar W8 heads or the 15^ X heads that never made it to John Q Public
A single 4 drag race motor on kill should make 2.5-2.6 HP per cube with a sheet manifold, a little less with a good cast piece.
Like Leon said, Carl does in fact still to this day say that the W8 is the best small block race head ever made, period.
I do have a set of P7 heads on an R5 that we have been working out for Comp Eliminator. We had every trick in the book done to our W8 stuff (CFE)
and to be honest the P7 heads we have here (started from a bare casting, CFE) have it all over the best W8 heads we had. The problems are that although we have countless R5-P7 parts, nothing will work now, its all custom. But I dont know of anyone else working these out for Comp so like the small inch W8-R4 stuff we had it will take time and time and time and well.....TIME.
Happy New Year to All!!!!
Rick Liuzzo
Re: W9 or P7 ? [Re: Domino1609] #50909
12/31/07 12:22 PM
12/31/07 12:22 PM
Charleston, SC
SCDaytona Offline
SCDaytona  Offline
Charleston, SC
Rick: You getting the itch to get back into Comp. or is this P7 engine for someone else? Why not use the P5's?
Re: W9 or P7 ? [Re: Domino1609] #50910
12/31/07 06:21 PM
12/31/07 06:21 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Very informative post.I'll keep dreaming while playing with my W-2 & W-5 stuff.One of these days I'll step up
Re: W9 or P7 ? [Re: DavidDean] #50911
12/31/07 06:30 PM
12/31/07 06:30 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I love my W8 CFE's.
I would not build a round-d-round W8 for what I try to do. That said I am buying up parts to do a round-d-round P7 head engine to spray the crap out of. Can't beat the price of the heads. Now I am running into a delima on valves that were supposed to be dirt cheap. Can not find the size I need. So $2,000 in new valves will ruin the cheap price of what I have.
Leon
Page 2 of 4 1 2 3 4
