comp cam kit....need opinions #508753
10/27/09 12:48 PM
10/27/09 12:48 PM
NC
Tommy383 Offline OP
Tommy383  Offline OP
NC
http://www.summitracing.com/parts/CCA-K21-233-4/
looking at this cam for my setup.
here is what i have:
520 cid
victor 440 heads
10.5:1 comp
tunnel ram
no carbs yet
any opinions on the cam?
thanks
Re: comp cam kit....need opinions [Re: Tommy383] #508754
10/27/09 01:16 PM
10/27/09 01:16 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
That cam should work pretty good, even better on a 108, i ran a similar one in an iron head 451 lowdeck with a TR & 600vs holleys. & it loved it, my cam was a custom piece from comp. based off there 540/520 solid. I would find out were the heads flow & have one custom ground. remember those are gross lift #s, so once you factor in the lash, it'll be less, i would shoot for something around .570/.580 gross.
543/529 gross lift
250/256 @50 on a 108
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
