Vacuum Pump install without a motorplate? #508383
10/26/09 07:16 PM
10/26/09 07:16 PM
Anonymous OP
Anonymous OP
has anyone ever ran and installed a vacuum pump without a motorplate?
does anyone make a bracket to mount to the head, iwant to install one on my 65 plymouth. i dont run a motorplate,just motormounts?
Re: Vacuum Pump install without a motorplate? #508384
10/26/09 09:52 PM
10/26/09 09:52 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Just make a plate that sits between the block and water pump off to the one side and mount it on there. Actually its easy.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Vacuum Pump install without a motorplate? #508385
10/26/09 09:59 PM
10/26/09 09:59 PM
Anonymous OP
Anonymous OP
ARC should be able to fix you right up. lots of guys do it without a motor plate.
Re: Vacuum Pump install without a motorplate? #508386
10/27/09 06:01 AM
10/27/09 06:01 AM
Anonymous OP
Anonymous OP
DRAM thanks so much for your informative answer, i'll get right on that!
Re: Vacuum Pump install without a motorplate? #508387
10/27/09 06:02 AM
10/27/09 06:02 AM
Anonymous OP
Anonymous OP
anyone have a picture of how it can be done?
Re: Vacuum Pump install without a motorplate? #508388
10/27/09 09:15 AM
10/27/09 09:15 AM
North of Detroit
HemiDart68 Offline
HemiDart68  Offline
North of Detroit
mounted to the head, not the motor plate, i had to make the braket
In God we trust, all others pay cash. www.lightnens.com (Home of the world's fastest Paint Job)
Re: Vacuum Pump install without a motorplate? [Re: HemiDart68] #508389
10/27/09 09:17 AM
10/27/09 09:17 AM
North of Detroit
HemiDart68 Offline
HemiDart68  Offline
North of Detroit
one more
Re: Vacuum Pump install without a motorplate? [Re: HemiDart68] #508390
10/27/09 04:44 PM
10/27/09 04:44 PM
Anonymous OP
Anonymous OP
one more
Matt, thanks very much for the picture, im rnning same low mount alternator and bracket , so that setup is identical to what i'm looking for,
any chance you have a picture of that bracket? thanks again. Chris
Re: Vacuum Pump install without a motorplate? #508391
10/27/09 06:25 PM
10/27/09 06:25 PM
North of Detroit
HemiDart68 Offline
HemiDart68  Offline
North of Detroit
No thats all i have, and the car is in a far away land. All we did was make a quick template out of cardboard to fit the pump. There is bolt through the bracket that you cant see that the plate pivots on, then just picked up the other bolt hole on the head. Then just kind of cut it on the band saw. Had to put it on a bridgeport to cut the radius so you could use the plate as a tensioner.
Re: Vacuum Pump install without a motorplate? [Re: HemiDart68] #508392
10/27/09 06:53 PM
10/27/09 06:53 PM
Anonymous OP
Anonymous OP
i'm liking that alot. is the bracket you made, the red billet aluminum piece?
i understand now what you did,looks great.
Re: Vacuum Pump install without a motorplate? #508393
10/27/09 07:04 PM
10/27/09 07:04 PM
Inver Grove Heights, MN
69_6bbl_Runner Offline
super street
super street
Who you trying to kid....just write the check
Re: Vacuum Pump install without a motorplate? #508394
10/27/09 07:36 PM
10/27/09 07:36 PM
North of Detroit
HemiDart68 Offline
HemiDart68  Offline
North of Detroit
Yes sir, made the red piece behind the vacum pump.
