The AR53 have a 13/16 wrench size and the AR3923 have a 5/8 wrench size but all the other measurements are the same. The reason I listed the Champion number was I couldn't remember the Autolite number I used with the Eddy's in the Challenger. Oreilly's didn't have the AR53 so I am going to use the AR3923.
They worked great in the Challenger and the motor I'm putting in the Daytona is almost the same. I'm using the same cam but instead of the Eddy RPM's with a Victor 440 it has Stage VI's with an M1 with a custom Dominator, same compression.
