A body brake change help #507570
10/26/09 12:29 AM
10/26/09 12:29 AM
Iowa
Rodder Offline OP
Rodder  Offline OP
Iowa
I have a 69 barracuda with KH disc brakes. The car sets a lot and they leak the fluid out. I would like to keep it small bolt pattern. Has anyone changed to maybe 70-72 small bolt disc brakes with the single calipers (that you can get parts for). Is there any problems with that change, original arms still work? Can you just change spindles and rotors and go? Or does anyone know any sources for Kelsey Hays rebuilding? However I don't think re building them will solve the setting problem.
Re: A body brake change help [Re: Rodder] #507571
10/26/09 12:33 AM
10/26/09 12:33 AM
where specifically is the leak?
Re: A body brake change help [Re: RapidRobert] #507572
10/26/09 12:37 AM
10/26/09 12:37 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
All a-body small bolt disc brakes are Kelsey-Hayes four piston calipers up through the 1972 model year. If you have leaky calipers you need to fix them and get clean brake fluid in the system.
Re: A body brake change help [Re: Jim_Lusk] #507573
10/26/09 02:11 AM
10/26/09 02:11 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
And I just saw at a shop some rebuilt ones on exchange for under $60 ea. Looked nice.
Re: A body brake change help [Re: Rodder] #507574
10/26/09 06:34 PM
10/26/09 06:34 PM
Iowa
Rodder Offline OP
Rodder  Offline OP
Iowa
Thanks Jim, I was not aware that KH were used past 69. That answers that. My pistons leak and drain the fluid out of the master cylinder. I put new cups in it and it helped for a couple of years and now I have let it set for about 7 months and they have leaked out again. I suppose I could get creative and redrill the 73 up rotors for small pattern. I doubt that is done much. But I think I would get a lot of money in having the KH calipers rebuilt. Thanks again.
