Re: ProMax Carbs metering plates
[Re: RapidRobert]
#507313
10/25/09 09:00 PM
10/25/09 09:00 PM
Posts: 1,086 Baton Rouge, La.
StandOnIt
Baton Rouge, La.
Tell us about your engine and what jets are in there. How is it without the powervalve? Oh wait, thats a 6pk huh? nevermind the powervalve. Sweet setup..
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
[Re: RapidRobert]
#507314
10/26/09 02:10 PM
10/26/09 02:10 PM
Posts: 1,046 Colorado Springs
T/A CARe
Colorado Springs
What is a good total advance number for a 340 (@ 6.000 feet)?
35 (vac disconnected/plugged). 31 w mag heads
Car has Magnum "J" 2.02 (I said "x" by accident in another post) heads.
Don't understand if you're asking a question with the "35 (vac disconnected/plugged)". I can go either way, but I usually run with the vac advance connected to the distributor. It's a street car with an automatic.
[Re: T/A CARe]
#507315
10/26/09 02:30 PM
10/26/09 02:30 PM
RapidRobert
The J head would not be a magnum head. 35 is a very accurate baseline for a SB total and you check that with the vac adv disconnected/plugged & the RPM up to where the mechanical weights/springs wont advance anymore. After checking it then you hook the hose back up.
[Re: aarcuda]
#507320
10/27/09 12:07 AM
10/27/09 12:07 AM
T/A CARe
Colorado Springs
I have 84's in mine and it runs great. what outboard springs do you have?
I have 84 jets in the plates too. I certainly "feel" them up top! Rather than the engine going limp at about 5,000 rpm it continues to pull past 6,000. Right now I have the blacks for mpg (if there is such a thing. ) I've run the yellow with 2 coils cut off too. I'll run them on the dyno tomorrow to see where they open.
RapidRobert-Thanks for the help. I'll play with timing on my pulls as well.
[Re: aarcuda]
#507327
10/28/09 12:07 PM
10/28/09 12:07 PM
Posts: 10,646 S.E.Ohio
Magnumguy
S.E.Ohio
Howdy stranger! Long time no see!
[Re: Magnumguy]
#507328
10/28/09 12:28 PM
10/28/09 12:28 PM
T/A CARe
Colorado Springs
Hey Bill! Yeah, the car's been in the paint shop for almost 2 years (for a 3 month job...) so I've not been doing much. Now it's out and I wanna have some fun, but before it went in, had a "carb shop" adjust it to pass emissions and now trying to straighten all that out... I've forgotten a lot of this stuff so I appreciate everyone's help and input! Blessings and T/A Care! Trip
