Which one of the E brakes pictured is correct for 1970 #507284
10/25/09 08:26 PM
10/25/09 08:26 PM
west kentucky
gomangoRTSE Offline OP
west kentucky
I bought my car, and so so much of it was in crates and baskets. I believe the upper one is the correct e brake, but I dont see where the cable is to connect the the one above.
Im not sure so if you can shine any light on the correct application of each E brake mechanism I would appreciate it.
Re: Which one of the E brakes pictured is correct for 1970 [Re: gomangoRTSE] #507285
10/25/09 10:42 PM
10/25/09 10:42 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
The upper one is the correct 70 unit...That small round hole in the bracket will line up with a round hole on the ratchet assy to slide the keeper pin through your cable end...Then just snap the retainer ring onto the pin and you're done...BTW, it's easier to install the pin/cable while the assy is out of the car then install as a unit through the firewall...
Re: Which one of the E brakes pictured is correct for 1970 [Re: screamindriver] #507286
10/25/09 11:30 PM
10/25/09 11:30 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Re: Which one of the E brakes pictured is correct for 1970 [Re: 1_WILD_RT] #507287
10/26/09 09:30 AM
10/26/09 09:30 AM
west kentucky
west kentucky
When you say the "small round hole" in the bracket, are we assuming looking at the picture thats its on the right side toward where it mounts to the firewall or the left side? Tks
Re: Which one of the E brakes pictured is correct for 1970 [Re: gomangoRTSE] #507288
10/26/09 01:14 PM
10/26/09 01:14 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Re: Which one of the E brakes pictured is correct for 1970 [Re: Snoopy] #507289
10/26/09 01:27 PM
10/26/09 01:27 PM
Snoopy Offline
Snoopy  Offline
70 Cuda
Re: Which one of the E brakes pictured is correct for 1970 [Re: Snoopy] #507290
10/26/09 01:27 PM
10/26/09 01:27 PM
Snoopy Offline
Snoopy  Offline
2
Re: Which one of the E brakes pictured is correct for 1970 [Re: Snoopy] #507291
10/26/09 01:28 PM
10/26/09 01:28 PM
Snoopy Offline
Snoopy  Offline
3
Re: Which one of the E brakes pictured is correct for 1970 [Re: Snoopy] #507292
10/26/09 09:50 PM
10/26/09 09:50 PM
west kentucky
west kentucky
So in the picture above with the RED circle in it, thats where the emergency cable end connects? In the above pic on the bottom of the E brake there is a small bolt and a clamp like......what is it for??
Re: Which one of the E brakes pictured is correct for 1970 [Re: gomangoRTSE] #507293
10/27/09 01:19 AM
10/27/09 01:19 AM
Snoopy Offline
Snoopy  Offline
Secures the brake cable.
