Re: The autopsy - windowed block
[Re: max_maniac]
#505726
10/24/09 11:21 PM
10/24/09 11:21 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
You gonna hang some curtains in those windows? ![](/ubbthreads/images/graemlins/laugh2.gif)
At least he's got the right color duct tape
[Re: max_maniac]
#505728
10/25/09 01:37 AM
10/25/09 01:37 AM
Posts: 43,372 Bend,OR USA
Cab_Burge
Me thanks the rod bearing locked up first, which siezed on the crank breaking the rod which hit the cam, breaking it making it fall down into the rotating crankshaft and ended up lodging, for a nano second, between the block main web and the rotaing crankshaft cracking the block, maybe not ![](/ubbthreads/images/graemlins/shruggy.gif) sorry for your loss ![](/ubbthreads/images/graemlins/frown.gif)
[Re: Cab_Burge]
#505729
10/25/09 02:07 AM
10/25/09 02:07 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Me thanks the rod bearing locked up first, which siezed on the crank breaking the rod which hit the cam, breaking it making it fall down into the rotating crankshaft and ended up lodging, for a nano second, between the block main web and the rotaing crankshaft cracking the block, maybe not sorry for your loss
You didn't get that much heat in the rod journal from a broken main web... The main bearings would tell that tale.. Those rod journals were smokin..
[Re: 1_WILD_RT]
#505730
10/25/09 02:31 AM
10/25/09 02:31 AM
Wow Russ, Looks like it had it's own little war going on in there...Looks like all you may salvage off of that one is the balancer bolt ![](/ubbthreads/images/graemlins/shock.gif) Let me know if you need any help ![](/ubbthreads/images/graemlins/wrench.gif) poppaj
[Re: max_maniac]
#505732
10/25/09 03:14 AM
10/25/09 03:14 AM
Posts: 1,612 Vista, California
ChickMaggot
Vista, California
They sell JB Weld at almost every parts store. Just thinkin' out loud.
You can lead a gift horse to water, but you can't look in his mouth.
#505736
10/25/09 07:06 AM
10/25/09 07:06 AM
Wow Russ, Looks like it had it's own little war going on in there...Looks like all you may salvage off of that one is the balancer bolt Let me know if you need any help poppaj
i think Russ wants to turn it up next year so i think he probably will pass on the help from you, IMO, remember he does want to go fast, ouch thats gonna leave a mark. ![](/ubbthreads/images/graemlins/wave.gif)
