challenger t/a tag/sheet questions #505638
10/24/09 09:38 PM
10/24/09 09:38 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
im wrapping up the resto on my t/a and now getting a better look at the paperwork and file that came with it. i found 2 small tags, that go under the fender tags, 1 cant see exactly what was stamped, the other has a 15 stamped in it, does anyone know what that means? also, anyone know where i can get the build sheet decoded (beside govier)? theres a spot on the sheet, line 7, that says "police engine" and theres a #8 in box marked from the factory. just wondering what that means? thanx to moparts and all its members for all your help throughout this resto, everyones been really great!
Re: challenger t/a tag/sheet questions [Re: kingkt] #505639
10/24/09 09:46 PM
10/24/09 09:46 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
The little tags or metal strips are some sort of QC tags that are not found on every car. I am not sure what the numbers stand for or if anyone has decoding info on them
People here on Moparts can decode your broadcast sheet and fender tag. Post pictures and folks here will have at it!
Re: challenger t/a tag/sheet questions [Re: kingkt] #505640
10/24/09 09:48 PM
10/24/09 09:48 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
It sounds like the small tags you have are inspection tags, but one is normal, got a photo? If so, yours was inspected by inspector 15.
F08 on your broadcast sheet is the T/A engine.
Re: challenger t/a tag/sheet questions [Re: Alaskan_TA] #505641
10/24/09 11:04 PM
10/24/09 11:04 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
heres the build sheet
Re: challenger t/a tag/sheet questions [Re: Alaskan_TA] #505642
10/24/09 11:09 PM
10/24/09 11:09 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
see if this works
Re: challenger t/a tag/sheet questions [Re: Alaskan_TA] #505643
10/24/09 11:10 PM
10/24/09 11:10 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
heres the tags
Re: challenger t/a tag/sheet questions [Re: Alaskan_TA] #505644
10/24/09 11:12 PM
10/24/09 11:12 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
see if this is more legible
Re: challenger t/a tag/sheet questions [Re: kingkt] #505645
10/24/09 11:17 PM
10/24/09 11:17 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
legible
Want some help with that?
Re: challenger t/a tag/sheet questions [Re: Alaskan_TA] #505646
10/24/09 11:20 PM
10/24/09 11:20 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
heres that small tag
Re: challenger t/a tag/sheet questions [Re: Alaskan_TA] #505647
10/24/09 11:22 PM
10/24/09 11:22 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
yeah, how can i make the picture bigger?
Re: challenger t/a tag/sheet questions [Re: kingkt] #505648
10/24/09 11:24 PM
10/24/09 11:24 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Easier if I do it from here from the copy you sent since I have a scanner. Give me a couple minutes......
Re: challenger t/a tag/sheet questions [Re: Alaskan_TA] #505649
10/24/09 11:29 PM
10/24/09 11:29 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
thanx, oh , by the way, ill take some pictures of the carb's tomorrow, i just took them out and they still have all the paper tags on them.
Re: challenger t/a tag/sheet questions [Re: Alaskan_TA] #505650
10/24/09 11:31 PM
10/24/09 11:31 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I cropped it as close as possible & cut it in two to keep as much detail as possible after resizing.
Top;
Re: challenger t/a tag/sheet questions [Re: Alaskan_TA] #505651
10/24/09 11:31 PM
10/24/09 11:31 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
hey barry, just curious what you would do...?i have an origial set of 340 carbs for another t/a, but they were used. ..would you put the old ones, or the new ones?
Re: challenger t/a tag/sheet questions [Re: Alaskan_TA] #505652
10/24/09 11:31 PM
10/24/09 11:31 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
bottom;
Re: challenger t/a tag/sheet questions [Re: Alaskan_TA] #505653
10/24/09 11:35 PM
10/24/09 11:35 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
On the carbs, it depends on what you want out of the car. If you are going to sell it or show it, the original date coded ones should go back on.
If you are going to keep it & drive it, use whichever ones you like, but keep the originals.
Re: challenger t/a tag/sheet questions [Re: Alaskan_TA] #505654
10/24/09 11:36 PM
10/24/09 11:36 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
glad you know what your doing on a pc. i know where the on off buttons are..
Re: challenger t/a tag/sheet questions [Re: Alaskan_TA] #505655
10/24/09 11:38 PM
10/24/09 11:38 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
both sets are originals, im adding the car to my collection. im not showing them, i just store them
Re: challenger t/a tag/sheet questions [Re: kingkt] #505656
10/24/09 11:40 PM
10/24/09 11:40 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
You should consider bringing it to Carlisle next July for the 40 Year Anniversary of the AAR & T/A.
Re: challenger t/a tag/sheet questions [Re: Alaskan_TA] #505657
10/24/09 11:47 PM
10/24/09 11:47 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
i may just do that.. thanx for the info
