According to the small block Mopar Performance book, piston p4529421 is a cast, 0.030" oversize, flat-top 340 piston and will give you 9.0:1 compression. However, that's all it says, it doesn't give any other specs.
Does anyone happen to know the compression distance for this piston so that I can calculate the compression ratio for my application?
Thanks!
