how to make factory undercoating look like new?
#504734
10/23/09 04:15 PM
10/23/09 04:15 PM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
on my 71 roadrunner, the original undercoating is just gobbed on, and I dont want to spend the time to get it cleaned off for a clean underside, so my next option is to make it look like 'new'. I know people have just sprayed more over it, but I want to see if there are any other options out there to make it look black once again. any help is appreciated. -kevin
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
Re: how to make factory undercoating look like new?
[Re: 70440+6bbl]
#504742
10/24/09 02:08 PM
10/24/09 02:08 PM
Posts: 4,848 Memphis
HemiRick
Memphis
I've had great luck with purple power cleaner and a scrub brush....A pressure washer will also work wonders.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#504743
11/10/09 04:34 AM
11/10/09 04:34 AM
Posts: 1,187 USA
big-block-dave
USA
Does anyone sell undercoat/sound deadener and a gun to get the texture and wide pattern that is factory original looking on the inside of the quarter panels? Also how about the thick body sealer and gun(i'm guessing that's how it was applied) for like the trunk/floor/extention seams or front floor pan to bottom of fire wall?
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
[Re: LimeliteAero]
#504745
11/10/09 03:10 PM
11/10/09 03:10 PM
Posts: 1,187 USA
big-block-dave
USA
Yes, your correct on the floor pan stuff, black. Trunk gets painted over. Did you get the trunk sealer to look close to factory? If so how did you apply it? Dave
[Re: big-block-dave]
#504746
11/10/09 04:03 PM
11/10/09 04:03 PM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
Squirt it on heavy and take the end of a paint stick and run over the sealer. Matches perfectly
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: MOPARMIKE69]
#504747
11/10/09 06:34 PM
11/10/09 06:34 PM
Posts: 6,585 SE Pa.
LimeliteAero
SE Pa.
I used my finger while wearing a cheap green vinyl glove.
I saw in the past where people used the paint stick method but after examining my car and using existing areas of the sealer that I did not need to address as a guide for appearence I was more than happy with my results. I did not replace any metal in the trunk. I was simply digging out and replacing dried and crumbling sealer. some areas that were very heavy with sealer I did nothing more than squeeze it from the caulking gun and leave it at that. The car is at the body shop otherwise I would take some pics to show.
[Re: HemiRick]
#504748
11/11/09 02:33 PM
11/11/09 02:33 PM
Posts: 4,261 State of Fascism
52savoy
State of Fascism
good choice..it does a real good job of cleaning anything that is petro based.
[Re: 52savoy]
#504749
11/11/09 05:28 PM
11/11/09 05:28 PM
Posts: 182 NW of Indy
Thackdaddy
NW of Indy
I used the rust-oleum undercoating and was very happy. It is low gloss black, with no texture.
'71 Duster
[Re: mopars_1]
#504750
11/11/09 06:48 PM
11/11/09 06:48 PM
Posts: 27,484 So Cal
autoxcuda
So Cal
Read here. This is a "how to" make old undercoating and broken off and missing sections look new again.
https://board.moparts.org/ubbthreads/show...rue#Post5514792
[Re: autoxcuda]
#504751
11/12/09 01:43 AM
11/12/09 01:43 AM
mopars_1
Ridgeland Wi
thanks everyone for the replys! Ill first try the degreaser and see how that works. thanks again! -kevin
