Re: Identifying where a 440 came from....
[Re: Pat_Whalen]
#503682
10/22/09 02:28 PM
10/22/09 02:28 PM
Posts: 1,373 Rancho Cucamonga, CA
D_C
You should be able to sort out the history a bit by copying down the VIN and Fender Tag numbers plus the numbers on the engine/cylinder block. There are Factory Number Decoders to help in converting those numbers to determine what you have/where it came from originally. Year One Mopar Engine ID Decoding Year One Mopar Engine Casting Numbers Mopar Broadcast Sheet Fender Tag Codes Also, you could always Post the numbers you find on the VIN and Fender Tags here (on Moparts) for help in decoding. IIRC, the last year the factory produced the 440 was 1979, so I'm guessing that it was not available in 1980. If that is correct, it was not the "original" engine for that vehicle. From your description it sounds like some previous owner got creative in mounting the engine. It can be remounted correctly with the right parts, either factory or aftermarket (like adapter-mounts from Schumacher Creative Services, etc.) Schumacher Creative Services Here is a (poor) photo I found on the internet of a 440 in a Ramcharger. You could look for better images on the internet and/or some member here (with a 440 Ramcharger) may well post a better picture. You could start a New Post requesting Engine-Compartment photos of Ramchargers with 440's. Good Luck with it.
[Re: D_C]
#503683
10/22/09 02:34 PM
10/22/09 02:34 PM
Posts: 15,487 Florida
scratchnfotraction
the hole in the MM for the oil pump is for a 4x4 2x4 are not like that I just put a 440 in a 85 2x4 and the are made out of 2x4 square stock and it sit further back and does not need the hole in it the cross frame (k-frame) is diff between the 2 sound like it is correct,IMO the MM from a motor home will not work..close but no go ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: scratchnfotraction]
#503684
10/22/09 05:21 PM
10/22/09 05:21 PM
Posts: 4,481 Mesa, AZ
Pat_Whalen
super gas
super gas
Mesa, AZ
The problem is that the hold in the driver's side mount for the oil filter adapter was cut with a torch. I don't believe these brackets to be correct. Is there any way motor home mounts will actually fit, but locate the engine in an entirely wrong position, like it currently is sitting? Perhaps some pictures would help....
[Re: elmor]
#503687
10/22/09 11:41 PM
10/22/09 11:41 PM
Pat_Whalen
super gas
super gas
Mesa, AZ
[Re: Pat_Whalen]
#503688
10/22/09 11:58 PM
10/22/09 11:58 PM
Posts: 2,042 Leucadia, Ca.
vdriver
Leucadia, Ca.
These are standard 4x2 440 truck brackets:
[Re: vdriver]
#503689
10/23/09 12:01 AM
10/23/09 12:01 AM
vdriver
Leucadia, Ca.
And these are 4x4 brackets:
[Re: vdriver]
#503690
10/23/09 12:05 AM
10/23/09 12:05 AM
vdriver
Leucadia, Ca.
Another pic of 4x4 brackets:
#503693
10/23/09 08:58 AM
10/23/09 08:58 AM
Pat_Whalen
super gas
super gas
Mesa, AZ
those mm are for a rv and the wrong ones IMO
I guess I'd probably be better off then finding a set of proper 4wd 440 mounts from a truck....
Off to the parts wanted section ![](/ubbthreads/images/graemlins/smile.gif)
Thanks felluhs.
[Re: Pat_Whalen]
#503694
10/23/09 10:34 AM
10/23/09 10:34 AM
Posts: 2,682 Clinton Twp. Michigan
coronet1966d
Thanks felluhs.
good luck ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: coronet1966d]
#503695
10/25/09 04:27 AM
10/25/09 04:27 AM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
I would see how low the motor is sitting. The ds looks like it's bolted in correctly. The passenger side you can drill/slot another hole for that biscuit mount to sit properly. Make sure it's level and see if you have any clearance issues with draglink and booster. They may work perfectly for you.
Moparlee
