Quick header question...
#503276
10/21/09 09:39 PM
10/21/09 09:39 PM
Posts: 322 San Diego, CA, United States
Texas_Charger
I am looking at buying a pair of headers. I found a set but I need y'all advice. The flanges are not one whole piece on each side, meaning they are seperate for each primary tube. I'll add a pic for reference. Do y'all know if this will affect the seal? I have never seen this and I wanted to know if they will leak or not. Thanks!
Nascar_Imperial
1971 Dodge Charger SE 470/727/3.91 Suregrip 2016 Dodge Challenger Hellcat, 6-speed 1980 Pontiac Trans Am, Y84, WS6 2002 Ram 2500 Cummins/6-speed/2WD/QC 1971 Ford F-350 Ranger
Re: Quick header question...
[Re: Texas_Charger]
#503278
10/21/09 09:47 PM
10/21/09 09:47 PM
Posts: 3,386 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Hard to say. Might even help.
A lot of guys with chronic leaks end up cutting the flanges between #1 and #3, #5 and #7, #2 and #4 and #6 and #8 anyway. Some say it helps minimize leaks if the flange is somewhat warped.
Should be fine if the flanges are thick enough.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: topside]
#503282
10/22/09 11:56 AM
10/22/09 11:56 AM
Posts: 3,968 North Riverside IL & Lowell IN
GTXKen
super gas
super gas
I do that to my headers if they don't come that way, and I don't have leaks. I believe a long connected flange warps and pulls the tubes away from the head. I've seen it enough times that I started separating my flanges 20 years ago or so. Less weight, cleaner appearance, better plug acess & visibility are other advantages. I'd say headers with connected flanges are made that way for ease of production due to less set-up time.
I do the same and for the same reasons, cut a brand new set for the GTX
[Re: GTXKen]
#503283
10/22/09 12:35 PM
10/22/09 12:35 PM
Texas_Charger
Thanks! How thick should the header flanges be?
[Re: Lefty]
#503286
10/23/09 06:45 AM
10/23/09 06:45 AM
Texas_Charger
Awesome, I really appreciate the help. So when I buy gaskets, is remflex the best? Which ones have y'all had the best luck with? Thanks
