Re: What kind of HP gains with electric water Pump and fan?
[Re: 65_gt_rag_402]
#503234
10/22/09 09:48 AM
10/22/09 09:48 AM
Posts: 13,416 Marion, South Carolina [><]
an8sec70cuda
I dropped a tenth by getting rid of the clutch fan, but still using the belt driven water pump. This was when I was running high 11s. Dropped another tenth w/ an electric water pump when I was running mid 10s. I've always run w/ an alternator. CHIP
[Re: BobR]
#503235
10/22/09 09:49 AM
10/22/09 09:49 AM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
we did back to back testing with a 360 auto 4.30 setup in the november 08 issue of Mopar Enthusiast you can read it online at www.moparenthusiast.comfrom a stock pump and fan to an electric fan / water pump combo The mechanical pump fan ran an 11.75 @113 the Meziere electric unit ran an 11.53 @115 they were ran back to back after swapping -
[Re: DJVCuda]
#503236
10/22/09 12:13 PM
10/22/09 12:13 PM
Posts: 8,165 Left Coast
BobR
Left Coast
That's pretty impressive, actually.
[Re: BobR]
#503238
10/22/09 12:17 PM
10/22/09 12:17 PM
DJVCuda
Atco NJ
I was surprised... read the article - Dan is a member here and did an excellent job wrenching that day!
[Re: 65_gt_rag_402]
#503240
10/22/09 02:08 PM
10/22/09 02:08 PM
Posts: 7,506 Az
Crizila
Az
Every time I toss a belt ( pump & alt - no fan as it is electric ) I gain .13.
Fastest 300
[Re: Crizila]
#503241
10/22/09 02:42 PM
10/22/09 02:42 PM
Triple Threat
Renton Washington
I ditched a clutch fan for an electric with shroud. I saw no firm gains, maybe a couple hundredths at most. Still running the stock water pump though, I'd switch over if i knew the car was gonna pick up, but I'm not so certain.
[Re: Cab_Burge]
#503243
10/22/09 03:44 PM
10/22/09 03:44 PM
BobR
Left Coast
How much improvement are you guys seeing with a electric water pump and electric fans ? HP or ET's ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) Thanks inadvance !!
I have tested removing the water pump belt(no alternator, tight water pump belt only) on two different 440 motors on two different engine dynos, 8 HP gain on both
That's more like what I expected.
[Re: an8sec70cuda]
#503244
10/22/09 06:44 PM
10/22/09 06:44 PM
Posts: 6,847 Missouri
StrokerPost
Missouri
The 2 tenths I shaved off was also while using an alt. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: StrokerPost]
#503245
10/22/09 11:01 PM
10/22/09 11:01 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
Years ago with my ld car I dialed in at 10.49, water pump belt blew off at the launch and I went 10.29! I was exstatic driving back to my pit til I saw steam under the hood, now I'm in a habit of watching all my gauges. Even with an alternator I was running 2 tenths quicker after the changeover, and easier to cool between rounds.
[Re: StrokerPost]
#503246
10/23/09 09:31 AM
10/23/09 09:31 AM
Posts: 333 So. Jersey
Somerdale Flash
So. Jersey
A little over 2 tenths on my SB Dart.
Same results here on 3 of my cars.... Along with 2 mph gain.
[Re: Quicktree]
#503249
10/23/09 11:03 AM
10/23/09 11:03 AM
Posts: 1,532 off the grid
340B5
off the grid
Yes, it is .10 improvement on my car if I turn the alternator off. I have a switch to open the field circuit.
Yeah, it's got a smallblock.
