Re: Is anyone using Evans coolant?
[Re: wrenchinrandy]
#502833
10/21/09 04:32 PM
10/21/09 04:32 PM
Posts: 8,165 Left Coast
BobR
Left Coast
I am curious if anyone has any experience with Evans NPG+ in their Mopar. The info that I have read all seems to make sense, but I question whether the sources are unbiased. The stuff is very expensive and not easy to find. On the other hand, if it is true to its' claims it seems like some amazing stuff. Has anyone tried it? Thanks.
I use it in my Challenger and my SC Cobra replica. I really like it but you should have a bit of extra cooling capacity as it does not transfer heat quite as well as conventional coolant mixed with water. It does greatly reduce hotspots and completely eliminates electrolysis related metal transfer.
[Re: BobR]
#502834
10/21/09 04:44 PM
10/21/09 04:44 PM
Posts: 27,484 So Cal
autoxcuda
So Cal
It doesn't transfer heat as well as water+coolant? Straight water will transfer heat better than water+coolant.
Did your temperatures go down after Evans? Was there an issue you had that went away or was reduced?
[Re: BobR]
#502835
10/21/09 05:36 PM
10/21/09 05:36 PM
Posts: 26,027 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Evans makes no claims as to better heat transfer, the main reason for using it is to prevent boiling at temperatures well above the temperature that other coolants boil even with high pressure caps.
I've been tempted to use in in one of my non-Mopar cars that has a cooling problem but I'm worried about what the elevated temperature will do to the oil; IOW, the Evans coolant might handle temperatures well in excess of 300°F but will the oil without an external cooler?
Also their literature states that any residual non-Evans coolant will reduce the effectiveness of their product so there's the hassle of trying to purge an existing system of all its coolant.
[Re: BobR]
#502836
10/22/09 01:45 AM
10/22/09 01:45 AM
Posts: 4,179 California
mickm
California
funny that this thread is up.
i saw a guy tonight at the local gathering with a cobra replica, 427 windsor, and he is running the stuff. he was showing how at 110 celsius, (his gauge is celsius), 230 F, you could take the cap off the radiator. so it was under no pressure even at 230 F.
he loves the stuff and swears by it. no rusting or corrosion of internal parts, especially bolts that go through water jackets, etc...
