Re: Broken Hemi pushrod cups
[Re: mt162]
#502749
10/21/09 12:15 PM
10/21/09 12:15 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
Was there any sign of heat or oil starvation? You need to make sure they are getting enuff oil. If it is oiling good, it could be valve to piston issues, valve float, tight guides, or pushrod to rockerarm clearance. Your lash should be more stable.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#502750
10/21/09 12:57 PM
10/21/09 12:57 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
All of the above as well as geometry and side loading,valve spring coil bind, and block or head to pushrod interference as well as cam base circle and lifter cup height.
[Re: mt162]
#502751
10/21/09 02:07 PM
10/21/09 02:07 PM
Posts: 4,213 New York
polyspheric
New York
More details? 1. lash caps? 2. what lift? 3. are you sure the stands are stock height?
Boffin Emeritus
[Re: Hemi_Joel]
#502752
10/21/09 02:40 PM
10/21/09 02:40 PM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
I have a bazillion of them. All oil starvation related at the tips. Going to fix that on the next go around...I have pics, but it sounds like you already know what they look like, but mine are all burnt looking at the cups.
And the lash issue is normal on aluminum heads the first time they pull in heat. Retorque the head bolts and all the valve train bolts and reset the valve lash. Pretty normal.
Post deleted by Defbob
[Re: Dragula]
#502753
10/21/09 02:51 PM
10/21/09 02:51 PM
#502754
10/21/09 03:21 PM
10/21/09 03:21 PM
Posts: 293 Kansas City Metro
mbogina
Kansas City Metro
Breaking pushrod cups with that light of spring pressure (and no burnt cups)is probably related to binding/side loading the cup due to either horrible valvetrain geometry (doubtful)or interference with the pushrod guide hole vs the lifter/pushrod/head gasket/adjuster assembly (probable).
Be a Rebel- Break the Laws of Physics!
#502755
10/21/09 03:31 PM
10/21/09 03:31 PM
Hemi_Joel
Minnesota
I burned up alot of rockers and pushrods years ago due to not enuff oil getting where it belongs. What I do now to solve oil starvation at the pushrod cups and roller rocker tips is grind the groove in the #4 cam journal oversize. I make it about .090 wide by .060 deep. That sends alot more oil to the top. And I run 10w30 oil, it gets to the roller tips much quicker on cold starts than thick oil does. I started the motor with no valve covers on to test this stuff and watch what the oil does. Not much gets to the tips and cups untill the oil warms up. Note the little squirt of oil trying desperatly to make it out to the rocker tip.
[Re: mt162]
#502759
10/21/09 05:06 PM
10/21/09 05:06 PM
mbogina
Kansas City Metro
If the pushrods are too long the pushrod tip could contact the rocker next to the adjuster and break the tip. You stated that you have a thread showing on the adjuster and that the rocker didn't show signs of interference, so the pushrod length is probaly ok. 375 lbs. open spring pressure at .620 lift does sound pretty light to me, but I am used to having more than that for seat pressure. The pushrods that are not damaged, do they show a proper "ball shaped" wear pattern? I have had some adjusters in the past where the ball end seemed to be a little too large in diameter, leaving only a "seat" in the pushrod cup. If that is the case, the pushrod tip could fail accordingly.
[Re: mbogina]
#502761
10/22/09 11:25 AM
10/22/09 11:25 AM
Posts: 123 Indiana
mt162
Indiana
The cups do look like the balls were riding on the sides and not touching on the bottoms. That's the only thing I've found so far. Guess I'll order new ones, torque the heads and try it again. Thanks to everyone for the inputs.
[Re: 3ddart]
#502764
10/22/09 09:43 PM
10/22/09 09:43 PM
#502766
10/22/09 09:49 PM
10/22/09 09:49 PM
Posts: 1,162 s e mich
ro23car
s e mich
this will cure any dry cup problems
is that thingamabobbie home made?
