what carb cfm? #502466
10/20/09 09:53 PM
10/20/09 09:53 PM
okla.
sam64 Offline OP
sam64  Offline OP
okla.
446,727,3500 stall,4.56 gear.14.5 32 15 m/t.foot brake.currently 1130 cfm rupert plugs look good after run but 1.50 60ft is it,jetted 90 square.thanks,sam.
Re: what carb cfm? [Re: sam64] #502467
10/20/09 10:02 PM
10/20/09 10:02 PM
Hemiroid Offline
Hemiroid  Offline
I'd use a 1000HP unless it has to be a dom. I like the 4150 on mild stock stroke 440's personally.
Re: what carb cfm? [Re: sam64] #502468
10/20/09 10:02 PM
10/20/09 10:02 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Well car weight, cam, cam install, intake track elevation can be big factors??
launch techneic launching off a brake at 6500 is way different than foot braking from 1000 idle????
