Where to get Brad Penn oil near Minneapolis???
#502365
10/20/09 08:38 PM
10/20/09 08:38 PM
Posts: 7,495 Minnesota
Hemi_Joel
Minnesota
I've been using Kendall GT for a long time, but now they just switched it to a synthetic blend, and the stores around here seem to be plum out of the older non-synthetic stuff. My previous dyno testing showed a significant power loss in my Hemi with synthetic, so I think I need to choose a new oil. Moparts members seem to recommend it alot, so I think I'll give Brad Penn a shot. None of the stores around my home town here have it on the shelf. Does anyone know if I can get it somewhere around Minneapolis? Thanks, Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Where to get Brad Penn oil near Minneapolis???
[Re: Hemi_Joel]
#502367
10/20/09 09:43 PM
10/20/09 09:43 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
Wheeler Racing in Blaine has it.
The little old lady from Pasadena is back!
[Re: Hemi_Joel]
#502370
10/21/09 12:09 AM
10/21/09 12:09 AM
Posts: 4,954 WI
Dcuda69
WI
FYI...not sure if it matters to you,but the 20w50 Brad Penn I have in my hand says "partial synthetic". It's called the"green oil" like the old Kendall GT-1 was.Just my
[Re: Dcuda69]
#502371
10/21/09 07:49 AM
10/21/09 07:49 AM
Hemi_Joel
Minnesota
Isn't that interesting??
I wonder how much synthetic is in Brad Penn and Kendall GT? Has anyone dyno tested the Brad Penn to see if it has an effect on power?
BTW, thanks for the replies!
[Re: 05dakota]
#502372
10/21/09 08:14 AM
10/21/09 08:14 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I am a stocking dealer in Syracuse, I know its still 2 hrs, but much closer than 4 hrs. Can get it to Utica, ( I actually have a dealer in Utica as well) if that helps.
Todd
RIP Monte Smith
[Re: Hemi_Joel]
#502374
10/21/09 07:39 PM
10/21/09 07:39 PM
Posts: 1,340 Pennsylvania
proshiftcharger
Pennsylvania
Joel, This may be a long shot so my apologies in advance if leading you on a wild goose chase. Im pretty sure if my memory serves me right that Ralph (moparts member: Rehbergerracing) is a Brad Penn Dealer. Im thinking he's in Illinois ?? Hope this helps. Doug
