Torque Converters not fitting into Crank????? #502279
10/20/09 07:06 PM
10/20/09 07:06 PM
oregon
ramcharger1964 Offline OP
oregon
Has anyone else had a problem with a big name converter nipple not fitting into the crank? I had to take nearly .020 metal (not paint) off of my converter to get it into the crank. This is a MAJOR convertor co (not cheap!)
Hell B!tch Racing Co.
Re: Torque Converters not fitting into Crank????? [Re: ramcharger1964] #502280
10/20/09 07:54 PM
10/20/09 07:54 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
NOt often but always check first.
Re: Torque Converters not fitting into Crank????? [Re: ramcharger1964] #502281
10/20/09 08:01 PM
10/20/09 08:01 PM
Peoples republic of clackamas ...
atoetly Offline
atoetly  Offline
I've had issues with them not welding the right size nuts on in-terms of having the snout bottom out inside the crank and then have to use washers to shim the converter back. But have not had an issue with a converter snout size since I was playing with an old 273 engine way back when. I would contact the converter manufacturer and tell them whats happened.
Re: Torque Converters not fitting into Crank????? [Re: atoetly] #502282
10/20/09 08:41 PM
10/20/09 08:41 PM
NC
chris3 Offline
chris3  Offline
NC
I have seen this happen. Problem was did not notice the problem and tore up a crank shaft and the main bearings. The problem was the crankshaft was not drilled properly. This was a big name crankshaft. When we checked the converter it had the proper diameter nose the back of the shaft was not correct.
Re: Torque Converters not fitting into Crank????? [Re: chris3] #502283
10/20/09 08:53 PM
10/20/09 08:53 PM
Hemiroid Offline
Hemiroid  Offline
I've experienced this as well. Pain in the butt!
Re: Torque Converters not fitting into Crank????? [Re: Hemiroid] #502284
10/20/09 11:19 PM
10/20/09 11:19 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Why does it hurt the crank and thrust bearings/main bearings if it is too tight??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Torque Converters not fitting into Crank????? [Re: hemi-itis] #502285
10/21/09 04:40 AM
10/21/09 04:40 AM
Kentucky
V
vern73 Offline
vern73  Offline
V
Kentucky
I had this happen on a PTC converter. The guy I talked to said something about they were expecting me to be using a motor plate between the engine and trans. and if I had one their converter would have fit. So I returned it and they fixed it. Then the nuts were welded on slightly out of position and I elongated the holes slightly in the flex plate. Not what I would have expected from a first class converter, but I must say they hit the stall # and the thing works great after resolving these problems.
Re: Torque Converters not fitting into Crank????? [Re: ramcharger1964] #502286
10/24/09 08:15 PM
10/24/09 08:15 PM
maryland
montyc Offline
montyc  Offline
maryland
I had an ATI where the snout was squared off and it needed to be rounded over. It wasn't too long it just didn't fit the radius in the end of the crank.
