how much oil pressure loss on non bushed 340`s #502253
10/20/09 06:24 PM
10/20/09 06:24 PM
indiana
mrart01 Offline OP
mrart01  Offline OP
indiana
would it b ok to run roller lifters in a 340 w/out bushing the lifter bores?I`ve heard u lose oil pressure.Thanks in advance
Re: how much oil pressure loss on non bushed 340`s [Re: mrart01] #502254
10/20/09 08:24 PM
10/20/09 08:24 PM
we do it all the time. it depends on the lifters you use, the lobe lift of the cam and the base circle of the cam in some cases.
Re: how much oil pressure loss on non bushed 340`s #502255
10/20/09 09:04 PM
10/20/09 09:04 PM
indiana
mrart01 Offline OP
mrart01  Offline OP
indiana
What type of lifters r u using?
Re: how much oil pressure loss on non bushed 340`s [Re: mrart01] #502256
10/20/09 09:43 PM
10/20/09 09:43 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
Several mfgs make lifters with a solid body which blocks the slot in the lifter bore,but I think you are limited to about .650 eff lift with a 1.50 rocker.
