evac system on a 340 #502210
10/20/09 05:27 PM
10/20/09 05:27 PM
indiana
mrart01 Offline OP
mrart01  Offline OP
indiana
what type of evac system should my friend b running on his 340 to get the most HP,right now it`s off the breather into the back of the carb.Thanks for any advice
Re: evac system on a 340 [Re: mrart01] #502211
10/20/09 06:40 PM
10/20/09 06:40 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
To get the most HP he should be running a vacuum pump.
Re: evac system on a 340 [Re: BobR] #502212
10/20/09 07:14 PM
10/20/09 07:14 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
OR if he wants to save $500.00 + and get around 5 - 7 " vac use this one . Available from Moroso or Jeg`s / Summit.
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: evac system on a 340 [Re: chryco] #502213
10/20/09 07:15 PM
10/20/09 07:15 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
More..... lower end.
Re: evac system on a 340 [Re: mrart01] #502214
10/20/09 07:35 PM
10/20/09 07:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Is this a car with muffler... if so get the vac pump,
the header type evac dosent like to work very well
with muffs... for every inch of back pressure in the
exhaust you loose a inch of vac... the vac pump you dont
Re: evac system on a 340 [Re: MR_P_BODY] #502215
10/20/09 08:18 PM
10/20/09 08:18 PM
indiana
mrart01 Offline OP
mrart01  Offline OP
indiana
He is running mufflers
