Quench vs. C/R vs. Fuel octaine #502160
10/20/09 04:23 PM
10/20/09 04:23 PM
Retired now in Tennessee
Chi_Town_Runner Offline OP
I'm in the porocess of building a 383/438 stroker.
On the KB calculator my computations come out as follows
Heads = 84cc
Piston Head volume = 4(valve reliefs on flat top pistons)
Gasket Thickness = .029
Gasket Bore -= 4.350
Cylinder Bore = 4.310
Deck clearance = .010
Stroke = 3.750
Computes to STATIC compression of 10.203
adding rod length = 6.760
Valve timing @ 6* Intake closing point = 38*
Dynamic CR = 9.472
I am trying to keep the quench at .040 so if I were to use a head gasket of .039 I would have the block decked for 0 deck clearance.
Will this run on the 91 octain I have available to me. If not what do I need to do to keep the quench but lower compression (if I have too)?
Frank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
Re: Quench vs. C/R vs. Fuel octaine [Re: Chi_Town_Runner] #502161
10/20/09 06:56 PM
10/20/09 06:56 PM
With those numbers I believe so and I'd make sure of all my measurements to get em exactly where I want them. If you go w full floating pins you can mock everything up, measure & easily pull the pistons to machine them for an exact zero deck height to go with your .039" gaskets. If needed you can enlarge/polish the chamber(s) with your porting burrs/tootsie rolls. Doesn't take much material to be removed.
Re: Quench vs. C/R vs. Fuel octaine [Re: Chi_Town_Runner] #502162
10/20/09 07:31 PM
10/20/09 07:31 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
Another way to increase chamber volume would be to put a D shaped dish in the piston under the chamber, so that your quench area is not reduced.
Re: Quench vs. C/R vs. Fuel octaine [Re: dynorad] #502163
10/20/09 07:37 PM
10/20/09 07:37 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
as it calculated, no. But I think your number for the intake valve closure is off. What cam is it? You need the spec for .050 lift... not .005 or .006 lift....
Re: Quench vs. C/R vs. Fuel octaine [Re: moper] #502164
10/20/09 07:54 PM
10/20/09 07:54 PM
They are full floating pins,
The cam (not yet purchased) is Comp Cams XR274HR-10 Hydraulic Roller (let the solid guys begin )
Duration I/E = 274/282
Duration I/E @ .50 = 224/230
Lift I/E = .538/.534
More thoughts
Frank
Re: Quench vs. C/R vs. Fuel octaine [Re: Chi_Town_Runner] #502165
10/20/09 09:23 PM
10/20/09 09:23 PM
Just read ano0ther post regard altitude. I'm at 6000 ft. How does altitude effect the C/R and pinging?
Frank
Re: Quench vs. C/R vs. Fuel octaine [Re: Chi_Town_Runner] #502166
10/20/09 09:25 PM
10/20/09 09:25 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Still need the ICA @.050" number from that cam ...
What's your altitude? If you're near 2500' you'll lose 10% of your cylinder pressure.
Re: Quench vs. C/R vs. Fuel octaine [Re: Chi_Town_Runner] #502167
10/20/09 09:27 PM
10/20/09 09:27 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
What heads? Eddys? Whats's your elevation above sea level?
Re: Quench vs. C/R vs. Fuel octaine [Re: Chi_Town_Runner] #502168
10/20/09 09:30 PM
10/20/09 09:30 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Frank
In that case your combo should be fine on pump gas. Altitude has a negative effect on compression/power. Unless you offer the info that you're at 6000' most guys will give you generic sea level advice that may not be best for an altitude build. At 6000' emphasis should be placed on cylinder pressures, otherwise you'll end up with a dog of a motor.
http://www.wallaceracing.com/dynamic-cr.php
Re: Quench vs. C/R vs. Fuel octaine [Re: Chi_Town_Runner] #502169
10/20/09 09:37 PM
10/20/09 09:37 PM
less atmospheric psi so less mixture drawn into the cyls making less dynamic CR & less likely to ping.
Re: Quench vs. C/R vs. Fuel octaine [Re: 64Post] #502170
10/20/09 09:57 PM
10/20/09 09:57 PM
Thanks,
But now how to alter or adjust cylinder pressure without effecting C/R or can't you?
Re: Quench vs. C/R vs. Fuel octaine [Re: Chi_Town_Runner] #502171
10/20/09 10:04 PM
10/20/09 10:04 PM
Wisconsin USA
Wisconsin USA
Cam timing, supercharging,turbocharging,nitrous
Re: Quench vs. C/R vs. Fuel octaine [Re: Chi_Town_Runner] #502172
10/20/09 10:19 PM
10/20/09 10:19 PM
the bottom line is cyl psi not CR & you want as much cyl pressure as your fuel will support wo pinging so if the build is in progress you want a higher static CR. If you're already together adv the cam (or a different cam), more (faster)timing and definitely the right cam/intake/carb to build as much intake mixture velocity in your desired rpm range to pack the cyls as full as possible.
Re: Quench vs. C/R vs. Fuel octaine [Re: RapidRobert] #502173
10/20/09 11:13 PM
10/20/09 11:13 PM
The cam has not yet been purchased. I'm taking the block to the machinist on Thursday so at this point I can make any adjustments with no downside.
Frank
Re: Quench vs. C/R vs. Fuel octaine [Re: Chi_Town_Runner] #502174
10/21/09 08:15 AM
10/21/09 08:15 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Frank , what heads , iron or alum ? Closed chamber or open ?
As far as machining each piston for perfect quench ... first off that's , second , it's impossible unless he had A CUSTOM piston made because a quench head piston for a 383 stroker DOES NOT EXIST , so if it's the custom the last thing I would be doing is cobbling up a $1000 set of pistons.
Re: Quench vs. C/R vs. Fuel octaine [Re: JohnRR] #502175
10/21/09 09:04 AM
10/21/09 09:04 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Like John said... easier to get tthe machining right then individually fit each piston..
I agree at 6000' you want more squeeze... I confess I'm a sea level guy so how much is too much I am not sure. I do know Comp doesnt publish the intake closing event but you should be able to get it from them by phone if you ask.
Re: Quench vs. C/R vs. Fuel octaine [Re: JohnRR] #502176
10/21/09 09:49 AM
10/21/09 09:49 AM
Heads
440source stealth 84 cc
Pistons are flat top with 2 valve reliefs
Compression height 1.320"
Thanks for any additional input.
I'll be on the phone today to Comp re specs. As I said, the cam has not been purchase yet so I have flexability with that. Any thought on that? I may post a new thread re: cam selection.
Frank
Re: Quench vs. C/R vs. Fuel octaine [Re: Chi_Town_Runner] #502177
10/21/09 10:18 AM
10/21/09 10:18 AM
I'd keep the cam inquiry in this thread, makes it easier to keep track of all your info. I will be machining each of my pistons (after my final decking) to get each one at .040". but I'm doing a 451 which does have quench dome pistons easily available as opposed to your 383 stroker. Good luck Frank. Make carefull decisions so you end up with a screamer.
Re: Quench vs. C/R vs. Fuel octaine [Re: moper] #502178
10/21/09 11:13 AM
10/21/09 11:13 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
my cam is a little [Email]259@.006[/Email], [Email]208@.050[/Email] hydraulic roller, 112LSA installed at 108, and my intake close point, going by .006" lift advertised is ~57.5 degrees ABDC.... 0.50 duration is 32 degrees ABDC....mine is a 318, 9:1 measured, no quench (.083" quench distance), and runs on 87 octane.
I'm guessing the number you really need to use to determine DCR is going to be closer to 60 deg. ABDC....
EDIT, seeing the cam you choice, 274 .006 intake duration (what comp uses for "advertised duration"), if installed at 106 ICL, would net you an intake close point 63 degrees ABDC, not 38. the KB calculator says to use .050 ICP+15 degrees, which nets 53 deg. ABDC. using .006 numbers you get
8.2 DCR, using the KB method nets 8.8....it should run fine on 92 or 93, you may have to be a little conservative with your distributor's timing curve.
2017 Grand Cherokee Overland
Re: Quench vs. C/R vs. Fuel octaine [Re: patrick] #502179
10/21/09 11:18 AM
10/21/09 11:18 AM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
And that will get your dynamic compression number to a more reasonable number. Mine is at 8.50 and I have a 10.5 to 1 calculated compression ratio.
