Transmission casting 34104321 whats it fit? #502155
10/20/09 04:17 PM
10/20/09 04:17 PM
monroe NC
1badssuv Offline OP
1badssuv  Offline OP
monroe NC
looking for the correct casting # to go back in my 70 challenger 340
Re: Transmission casting 34104321 whats it fit? [Re: 1badssuv] #502156
10/20/09 06:16 PM
10/20/09 06:16 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
i dont see it in my parts book.. maybe double ck the number.. i tried all forms of the last 4 numbers since there,s one extra as barry said below i forgot.. dan
Re: Transmission casting 34104321 whats it fit? [Re: ph23vo] #502157
10/20/09 07:36 PM
10/20/09 07:36 PM
monroe NC
1badssuv Offline OP
1badssuv  Offline OP
monroe NC
the guy tells me its a factory replacement,has no car vin #s stamped on it
anybody else got a clue?
Re: Transmission casting 34104321 whats it fit? [Re: 1badssuv] #502158
10/20/09 09:26 PM
10/20/09 09:26 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
i looked at just case #,s also no such number in my books dan
Re: Transmission casting 34104321 whats it fit? [Re: ph23vo] #502159
10/20/09 09:38 PM
10/20/09 09:38 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Casting numbers & parts numbers are seven digits, you listed 8.
You need to have him double check the number, a photo would be even better.
