Who sells rollmaster timing sets??
#501271
10/19/09 03:51 PM
10/19/09 03:51 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
I need a small block one for a 340 build.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Who sells rollmaster timing sets??
[Re: CJK440]
#501272
10/19/09 05:41 PM
10/19/09 05:41 PM
Posts: 1,880 USA
Ron Silva
USA
I think Ryan J said he was going to supply one for my 501 small block motor.
SRT DEMON ONE SEAT
[Re: torkrules]
#501274
10/20/09 07:07 AM
10/20/09 07:07 AM
Posts: 1,229 In The Hills
jughed
In The Hills
Muscle Motors in Lansing Michigan comes to mind.
beware of MM...i ordered a Rollmaster, they sent an Australian made timing set. When i called them about getting the wrong brand they claimed "they are the exact same thing, just different makers."
MM refunded the difference in price, but wouldn't have if i had not made the call. If you order from them, demand a Rollmaster set instead of the cheap set.
[Re: camdog440]
#501276
10/20/09 10:45 AM
10/20/09 10:45 AM
Posts: 6,151 Melbourne , Australia
LA360
The rights to making Rollmaster timing chain sets was sold to a company in Adelaide by the name of JP Products. They make their own range of timing chain set and I believe the only original part they make for the current Rollmaster units is the upper gear. The chain and lower gear are the same that are fitted to the JP units. So sadly, the Quality Romac made units we were all buying are no longer made. The current timing sets have a lower quality crank gear and do not run the Iwis chain. What Muscle Motors told you is correct. AL....
Alan Jones
[Re: Ron Silva]
#501278
10/20/09 03:02 PM
10/20/09 03:02 PM
Posts: 11,733 Portage,michigan
B3422W5
Portage,michigan
Knowing what i know now, no way in the world i would ever build a small block mopar motor from scratch and not use a gear drive setup especially if it was going to be raced at all.
Every timing chain i have ever seen stretches, and the problem is inherantly worse on small chryslers than pretty much anything else
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: B3422W5]
#501279
10/20/09 03:19 PM
10/20/09 03:19 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
That's good reason to put a $30 Melling timing tensioner on it.....
The "problem being inherent to SB Chryslers" is because of the long Cam to crank CL.
Milodon gear drives have gone up in price & are currently in the $370 range. Only time I really use them is on a 50 MM roller cam block.
Good Billet 9 keyway chain & tensioner setup is about $120... no machine work to block..... Gear Drive $370 + machining cost (drill/tap hole in block & on some applications must modify gear drive thrust plate)
Billet chain/tensioner setup will give you within 1/2 degree accurate cam timing for 1/3 cost. Most people just use whatever is in their budget....
[Re: RyanJ]
#501280
10/20/09 05:09 PM
10/20/09 05:09 PM
B3422W5
Portage,michigan
I know a guy who put a good chain in( he races a lot) and it was stretched in one season.
Of course a chain is cheaper, but why not do it once and be done. In a 10-12,15k motor, what is 200-300 bucks. If you have to swap out the chain, you have a lot of time and gasket set etc. A tensioner is nice, but lets face it, its a bandaid, not a fix.
[Re: B3422W5]
#501281
10/20/09 08:22 PM
10/20/09 08:22 PM
i don't usually use/sell the rollmaster stuff anymore. we use/sell the Pro-Gear timing sets with the Rolon chain and billet upper and lower gears. we see much less stretch than we saw with the rollmaster units. for smallblocks, the tensioner absolutely works. if it's a band-aid, it's a darn good one. ![](/ubbthreads/images/graemlins/thumbs.gif) besides that, i can't stand the whine of a gear drive on a street car.
#501283
10/21/09 11:39 AM
10/21/09 11:39 AM
B3422W5
Portage,michigan
i don't usually use/sell the rollmaster stuff anymore. we use/sell the Pro-Gear timing sets with the Rolon chain and billet upper and lower gears. we see much less stretch than we saw with the rollmaster units. for smallblocks, the tensioner absolutely works. if it's a band-aid, it's a darn good one. besides that, i can't stand the whine of a gear drive on a street car.
Who said anything about street car.I think i specifically said" if it was going to be raced at all" The unit we are talking about as i understand it isnt loud.I see zero negatives, and a ton of positives. I doubt you could hear it on a race car, maybe somebody who has one can chime in.
I cant believe we are debating the merits of a chain vs a gear.. its kinda a no brainer.
[Re: B3422W5]
#501284
10/21/09 12:07 PM
10/21/09 12:07 PM
RyanJ
moparts member
moparts member
State College, PA
Don, no offense but between DRAM & I, I think we've worked on a few more SB Mopars than you have W/ a chain.... Once a tensioner is installed W/ a GOOD chain, you will see no slop, no matter how much use. I run them on our dirt track cars that sit @ 7000-7600 all night long, & there is no slop after years of use. In fact one motor has same chain/tensioner on it for last 4 years......
Your buddy needs to put a good chain & tensioner on... there will be no slop, street car/drag car/dirt car etc.
If he runs a cast gear chain W/ no tensioner it WILL stretch, & it will stretch fairly quickly. I don't disagree that his did stretch, I'm just saying if he had bought & used proper parts the first time it would'nt have happened.
The Milodon gear drives for SB Chrysler do not whine or make any noise, if they did, I'd never have one on one of my cars, I can't stand that racket.
I do have a Milodon GD on my 394 Turbo motor, but again, it is a 50MM Roller cam motor. If it was Babbit bearing I'd have a billet chain & tensioner on it. Much better places to spend your $ on than a GD IMO. Just my experiences having built/torn down quite few SB motors with both drives & chains.... If I thought they were so much better than a chain/tensioner, I'd try to talk everyone into one.... instead I usually end up trying to talk them out of it.
[Re: RyanJ]
#501285
10/21/09 01:06 PM
10/21/09 01:06 PM
B3422W5
Portage,michigan
I admit you have built more motors than me...lol
I have had 3 stretched chains in my motors over the years, and i dont use cheap anything.Cloyes, JP, and i forget the other one.This in a less than 10 year period of not racing " all the time" by any means.
I can see why a dirt track car wouldnt be as hard on chains, they arent using things like trans brakes and accelerating from off idle to 7000 rpms in an instant hardly ever,doing burnouts where the motor isnt under load and accelerates extremely rapidly, way different usages. You of all people should know that is a terrible analogy..lol Having a car moving at 5000 rpm's and accelerating to 8000 rpm's isnt near as hard on anything except possibly valvetrain items.
Chuck at Best Machine suggested a Gear drive a long time ago, and i was hard headed and didnt go that way.Wish i had, if for some reason i still have my car next year it will withou a doubt get one.
Correct me if i am wrong but doesnt a timing chain stretching have no bearing whatsoever from a tensioner? Doesnt a tensioner just " take up he slack" or do i missunderstand its usage ?In other words the chain still stretches exactly the same, tensioner or not, just that its symptoms are masked/tensioned?
I know you work on motors, but i have almost 20 years of engineering experience( made a living at it) so i kinda know how stuff works..lol
Building 10,000 motors has nothing to do with comparing the merits of a chain and a gear ![](/ubbthreads/images/graemlins/biggrin.gif)
Re: Who sells rollmaster timing sets?? *DELETED*
[Re: B3422W5]
#501286
10/21/09 02:31 PM
10/21/09 02:31 PM
RyanJ
moparts member
moparts member
State College, PA
Post deleted by RyanJ
[Re: mopar dave]
#501288
10/21/09 02:52 PM
10/21/09 02:52 PM
B3422W5
Portage,michigan
i have to agree with b3422w5 on the chain stretching reguardless whether it has a tensioner or not. i don't have a degree in anything, i'm just a dumb truck driver but common sense tells me as the chain stretches the timing still would fall back reguardless if there's a tensioner in there to take up the slack or not. DONE
As i said earlier, the tensioner is just a band aid. It takes up the slack of the chain as it stretches. It doesnt " fix" anything.Is it better than not having it sure. Will the chain still stretch the exact same amount, sure it will.
Its like a car door on a big 2 door that creaks from being open and shut so many times. It needs new hinges put on it, but spraying grease on it will make it seem fine for a long time...but the wear is already there.
[Re: Ron Silva]
#501290
10/21/09 06:19 PM
10/21/09 06:19 PM
B3422W5
Portage,michigan
You say you are an Engineer and you cannot understand how having a good quality chain & gears OR a tensioner will help minimize or stop timing cain stretch?
THINK about what is happening "dynamically" in a running engine to these parts.
THINK about how a good quality part might do compared to some of the other junk out there.
What about this car door hinges that are worn out? What if they were made out of better materials? What if you used some HD rubber or polyurethane cushions to support and keep the door snug while the car is going down the road and when you are shuting the door. What if you used two striker pins instead of one and/or took some weight out of the door assymbly??
I hear ya Ron. yes, what if, what if, what if. Yes i have an engineering background ![](/ubbthreads/images/graemlins/biggrin.gif)
Yes i defer to how a car door is made to the engineers at Ford,GM, etc. They are way smarter than me. I notice that the bigger the door, the sooner it sags. Like for instance on Monte Carlo's.I am sure these engineers have devoted countless manhours to just this issue. Yes, i am sure they could make them better, why they dont, i havent a clue.
I know the Milidon gear drive would be more precise and last longer than a timing chain. And be more accurate the whole time.I have never, o my knowledge used a cheap chain, i have been dissapointed in the performance of several different ones, and come to the truthfull conclusion they all stretch, some maybe sooner than others, but they all do. I initally said in the whole scheme of things( building a 10-15 grand motor) a gear drive isnt that much extra money when you look at it. I have had several such motors built professionally, and have never used a gear drive.( Perhaps i am hard headed and a slow learner) If i was to do it again, i definately would though, as i have come to consider it a nice upgrade. I have went through a few chains, and have tried several different models. I am not just saying that ,i indeed have.Its just my opinion based on personal experience over the years of GOOD chains stretching, an excellent motor builder suggesting going to a nice gear drive setup, and that is about it. I just suggested you might consider going to one, that said, its just my opinion, nothing more or less. ![](/ubbthreads/images/graemlins/thumbs.gif)
