Re: no electrical power
[Re: stumpy]
#501133
10/19/09 02:54 PM
10/19/09 02:54 PM
RapidRobert
you might seperate the 2 or 3 black bulkhead connectors at the firewall & clean the terminals
[Re: mr.rt]
#501137
10/26/09 10:41 AM
10/26/09 10:41 AM
RapidRobert
NAPA has gm terminals(the small brass male/female ones) that are almost identical to ours & work fine.
[Re: mr.rt]
#501139
10/26/09 04:49 PM
10/26/09 04:49 PM
Posts: 5,450 So Cal
Sinitro
So Cal
Saturday I worked on the car, pulled the bulkhead connectors, cleaned them, reinstalled the fusible link & coated everything with dielectric grease & reassembled. car came back to life & everything is working. my new question is where can I get new bulkhead connectors as two of them have broken tabs. Thanks
What part are you referring to.. The metal 0.25" male tab connectors or the plastic block that holds the tab connectors..
Just my $0.015... ![](/ubbthreads/images/graemlins/wink.gif)
[Re: mr.rt]
#501140
10/26/09 05:52 PM
10/26/09 05:52 PM
Posts: 1,822 Colorado
denfireguy
Colorado
Ebay has the engine compartment side (3 plugs) but the main socket is part of the Year One only dash wiring harness. As the other posters have indicated, the individual terminals are available. They are "Packard" style terminals and are available form such places as EG&G terminal. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
