Bad Wiring? #501124
10/19/09 12:38 PM
10/19/09 12:38 PM
Lakeside, CA
DartCustom360 Offline OP
Lakeside, CA
Does anyone have an idea on why "All of the sudden" my reverse lights, radio, and turn signal stopped working? I recently installed an A/C kit from Classic Auto Air which went in very easy. It was a very simple install without any problems... All I'm trying to figure out is, why that particular circuit died... I retraced my steps over & over & over... NOTHING! I check the fuses and the wiring, even at the firewall.
I bypassed the turn signal switch directly to run off the hazard circuit (which works fine), but it's not the right way and I don't like it!
Is there a "Series Circuit" that controls the heater box? I'm completely at a loss.... Please help!!!
Thanks!
Re: Bad Wiring? [Re: DartCustom360] #501125
10/19/09 12:41 PM
10/19/09 12:41 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Did you check the turn signal flasher which is seperate from the emergency flasher?
Re: Bad Wiring? [Re: stumpy] #501126
10/19/09 01:58 PM
10/19/09 01:58 PM
Lakeside, CA
Lakeside, CA
Yes, there's no power to that either... I metered everything and there's no power.
Re: Bad Wiring? [Re: DartCustom360] #501127
10/19/09 02:59 PM
10/19/09 02:59 PM
The wiring diagrams at ww.mymopar.com will help you with color codes/routing to find the open with your VOM.
Re: Bad Wiring? [Re: DartCustom360] #501128
10/19/09 05:24 PM
10/19/09 05:24 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Well there are all the usual suspects:
Bulkhead connection
Ammeter bolts loose
Burned wires in between bulkhead connector and dash.
The only usual suspect that you have ruled out is the wiring in the steering column.
Nothing is wired in series. You will have to start at one end or the other and check voltages along the way. A diagram, as previously pointed out, will make the job possible. Without one, you could keep shooting in the dark for a couple of weeks.
Craig
Re: Bad Wiring? [Re: denfireguy] #501129
10/19/09 09:04 PM
10/19/09 09:04 PM
Lakeside, CA
Lakeside, CA
Thanks for all the feedback and the diagram. I will try it out! Wish me luck!!
