Re: A few questions about lexan windshields
[Re: 340_Dart]
#499543
10/17/09 03:22 PM
10/17/09 03:22 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
yes..lexan can use stock rubber gasket.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: TheBlackCar]
#499549
10/17/09 08:26 PM
10/17/09 08:26 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
Nothing like real glass especialy at night and in the bright sun. Think hard before you change up.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: '72CudaRacer]
#499551
10/17/09 09:15 PM
10/17/09 09:15 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have used 1/8" lexan for years on 1/8 and 1/4 mile. Pop rivited in & a single brace in the center, no problems. Shimed it out with scrap pieces of lexan, and clear sylicone sealed. Also painted a black border from the inside. You can cut it with a fine tooth blade in a jigsaw. Just take your time cutting it.
Brian Dunnigan
Also take a propane torch to finish the cut edges... just slowly pass it along the edge to re-melt it ... I usually draw file the edge first then hit it with a torch for a professional look. 3/16" is plenty for it but you would need to shim it too make up for the original windshield thickness PS... try it on a scrap piece first to get the idea. Also dont waste your money on the scratch resistant stuff it will scratch just as easy ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 340_Dart]
#499553
10/18/09 04:55 AM
10/18/09 04:55 AM
Posts: 699 Cooperstown, NY
jrlegacy23
Cooperstown, NY
Adam, I'm digging the Black prostars on the Valiant ![](/ubbthreads/images/graemlins/thumbs.gif) Looks awesome.
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
[Re: Dartwizer]
#499557
10/18/09 10:28 AM
10/18/09 10:28 AM
Posts: 4,292 Morrow, OH
markz528
Morrow, OH
I like my 1/8 inch Lexan. I use the stock rubber gasket but I use a rubber u channel from McMaster Carr that brings the thickness back to the factory 1/4 inch. Works very well for me but I also do use a center support.
[Re: markz528]
#499558
10/18/09 10:36 AM
10/18/09 10:36 AM
MR_P_BODY
I use 1/8" also, without a center support, yes it does bow in at speed but I really dont care, it goes back to normal when I slow down...mine bows in about 1"... It all depends on size of the windshield and how much arch there is in it to how much it will move ![](/ubbthreads/images/graemlins/wave.gif)
[Re: B G Racing]
#499560
10/18/09 11:49 AM
10/18/09 11:49 AM
Posts: 9,893 MI, usa
dvw
MI, usa
We use 1/4" aircraft lexan with the syock gaskets and it works great.
Bob,do you heat bend yours for early B-Bodys? If so how do you do it? If not how do you bend the lower corners into the rubber channel. I'm actually thinkinking of using 1/8". It seems to bend pretty easy. Doug
