Who has the better flat tappet 4 a 340? #499466
10/17/09 01:43 PM
10/17/09 01:43 PM
indiana
mrart01 Offline OP
mrart01  Offline OP
indiana
I posted my friends combo (need help w/ this 340 combo)& we are now looking to get a solid flat tappet cam ground based on his combo.Who would be the better choice for a strip 340?thanks for the help
Re: Who has the better flat tappet 4 a 340? [Re: mrart01] #499467
10/17/09 02:15 PM
10/17/09 02:15 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Racer Brown
Yeah, it's got a smallblock.
Re: Who has the better flat tappet 4 a 340? [Re: 340B5] #499468
10/17/09 04:13 PM
10/17/09 04:13 PM
COMP has a solid that flys under the radar but is one of the best cams ever ground for a hot 340 It is 255 at 050 540 lift--on a 340 or 360 it goes in at about 103 for 1/8th milers and maybe 104 ish for 1/4--a little more won't hurt but it LOVES 103 in most apps--that little cam with 1.5 rockers will FLY!! I have seen it out run all the more "scienced" picks year after year---I had one in a crate motor 360 duster and it would run 6.90 in the 1/8th all day long with TONS of torque--all the guys that had the bigger stuff couldn't hang with it---The better your heads the better it runs and it will turn a ton of RPM if you have the spring to do it--I always ran it a few weeks and then stepped the spring pressure up and BAM! The real secret is that it is on a 106 LSA--Bad A$$ small blocks love tighter LSA--I am speaking of 340-360 not strokers here---I did most of my testing and running with this on 1/8 th mile stuff---I have two on the shelf for future use--none better IMO---with the right converter and torque tubes on a great header it is amazing!
Re: Who has the better flat tappet 4 a 340? [Re: ] #499469
10/17/09 04:54 PM
10/17/09 04:54 PM
indiana
mrart01 Offline OP
mrart01  Offline OP
indiana
do you have a part # for that cam?
Re: Who has the better flat tappet 4 a 340? [Re: mrart01] #499470
10/17/09 05:19 PM
10/17/09 05:19 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I've been impressed with the Hughes cams I've had. The hydraulic in my 340 ran a best of 7.24 in the 1/8 at 3300#, low 7.30s in the heat, it was 237/242 @ .050 with .586/.592 lift with 1.6 rockers. My 408 has a Hughes flat solid with EDM lifters, 260/264 @ .050 with .626/.633 lift. So far it's ran 6.743 spinning, I think it has mid 6.60s in it. Call Dave
Re: Who has the better flat tappet 4 a 340? [Re: ] #499471
10/17/09 06:54 PM
10/17/09 06:54 PM
Utah
topbrent Offline
topbrent  Offline
Utah
COMP has a solid that flys under the radar ... 255 at 050 540 lift 106 LSA
That is CompCams Part Number: 20-618-5, Grind Number: 290A-6, 255 @.050, 290 Adv, .540 lift, 106°LSA
For some good education on what cam and why...
...I would recommend calling Tim Goolsby @ Bullet Cams.
We have had good success with a Bullet-Ultradyne Cams.
Tim will spec out a great cam for you.
http://www.bulletcams.com/
Call Bullet Racing Cams at (662)893-5670.
Re: Who has the better flat tappet 4 a 340? [Re: topbrent] #499472
10/17/09 07:19 PM
10/17/09 07:19 PM
K
KOS Offline
KOS  Offline
K
MP .557
Re: Who has the better flat tappet 4 a 340? [Re: 340B5] #499473
10/17/09 07:35 PM
10/17/09 07:35 PM
Ohio
Lil Wedge Offline
Lil Wedge  Offline
Ohio
Racer Brown
