RPM limit of a cast piston 360? #499038
10/16/09 08:28 PM
10/16/09 08:28 PM
Dallas, TX
The Wolf Man Offline OP
Dallas, TX
Disregarding any valvetrain issues, and looking strictly at the limits of the pistons, how high could you safely rev a stock cast piston LA 360?
Re: RPM limit of a cast piston 360? [Re: The Wolf Man] #499039
10/16/09 08:32 PM
10/16/09 08:32 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I never thaught the cast piston would be an issue unless it`s the Badger junk then the wrist pins pull out through the bottom if material`s removed from that area for balancing. I figured the cast piece`s limitation would be more based on nitrous, blowers, turbos etc.
Re: RPM limit of a cast piston 360? [Re: Thumperdart] #499040
10/16/09 08:47 PM
10/16/09 08:47 PM
IN
ahy Offline
ahy  Offline
IN
The 360 crate motors were designed to go to 6000 or so with a hypereutetic cast piston... depending on how your particular setup compares that may be a decent reference.
Re: RPM limit of a cast piston 360? [Re: ahy] #499041
10/16/09 10:18 PM
10/16/09 10:18 PM
Seaford Delaware
JSR1485 Offline
JSR1485  Offline
Seaford Delaware
My old race engine has Keith Black hypereutetic pistons and I twisted that to 7500 rpms. That engine had over 200 runs on it. I went 11.80 in my Duster with that engine.
Switched to the dark side...
Re: RPM limit of a cast piston 360? [Re: The Wolf Man] #499042
10/16/09 10:23 PM
10/16/09 10:23 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
I suspect the stock rod and rod bolts connected to the stock piston would let go first but I could be wrong. If there's doubt, just get better parts.
Re: RPM limit of a cast piston 360? [Re: dodgeboy11] #499043
10/16/09 10:35 PM
10/16/09 10:35 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'd say 6000-6500, since this sounds like a pretty stock motor.
Re: RPM limit of a cast piston 360? [Re: The Wolf Man] #499044
10/16/09 11:19 PM
10/16/09 11:19 PM
I know of a lot of NHRA "stock" class racers that rev the stock OEM Mopar pistons(before the aftermarket pistons where approved in stock) to 7000 rpms Those pistons where th original pistons, the cheater cams back then where pretty much done by 6400 RPM but some guys would rev them to 7000 to keep the converters lock up on the gear changes
Re: RPM limit of a cast piston 360? [Re: Cab_Burge] #499045
10/19/09 11:18 AM
10/19/09 11:18 AM
Haysville, Kansas
rdrmod6 Offline
rdrmod6  Offline
Haysville, Kansas
with the Keith Black pistons I used to turn my engine 7100 all of the time. at the end of the 4th season I did burn one but the problem was ring seal not the piston construction.
Re: RPM limit of a cast piston 360? [Re: The Wolf Man] #499046
10/19/09 11:57 AM
10/19/09 11:57 AM
Az
Crizila Offline
Crizila  Offline
Az
6000 rpm. Rule of for cast pistons / crank is 3500fpm piston speed. Stroke (3.58 ) X rpm (6000) divided by 6 = 3580fpm. I'm sure there are plenty of "experts" out there that will tell you they rev ther stock 360 to 8K all the time with no problems and if they are actually doing that, they really are experts!
Fastest 300
Re: RPM limit of a cast piston 360? [Re: Crizila] #499047
10/19/09 01:42 PM
10/19/09 01:42 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Lots of things that a lot say they do = to above statement.
