Page 3 of 3 1 2 3
Re: Mopar aluminum head P4876624 for Magnum 5.9l [Re: siggie30] #499002
11/13/10 07:55 PM
11/13/10 07:55 PM
Sarasota, Fl
siggie30 Offline OP
siggie30  Offline OP
Sarasota, Fl
I see the problem with my previous post. The springs I ordered are 1.290 OD, 0.885 ID. The head spring pocket is +/- 1.61 OD and +/- 0.555 OD of the valve guide. Any business persons want to provide a locator or cup to accomodate? Or anyone familiar enough to say which brand/company makes one? I have reviewed VSI, Comp Cams, and the mopar sites to no avail.
I don't even have 1/2 lift, but the other 1/2 is nitroused.
Re: Mopar aluminum head P4876624 for Magnum 5.9l [Re: siggie30] #499003
11/19/10 08:05 PM
11/19/10 08:05 PM
Sarasota, Fl
siggie30 Offline OP
siggie30  Offline OP
Sarasota, Fl
Thanks to Hotroddave for the inspiration to push forward. I ordered some locators from Comp so as I see it, the IH will be approx. 1.71- 1.73. which kind of works out as the springs relax they will be as spec'ed by most.
Re: Mopar aluminum head P4876624 for Magnum 5.9l [Re: siggie30] #499004
11/25/10 05:29 PM
11/25/10 05:29 PM
Sarasota, Fl
siggie30 Offline OP
siggie30  Offline OP
Sarasota, Fl
There you go, GM springs and retainers on Mopar valves.
Page 3 of 3 1 2 3
