Can anyone decode these trans numbers? #498951
10/16/09 07:19 PM
10/16/09 07:19 PM
a cornfield near you
BlakDak Offline OP
BlakDak  Offline OP
supposedly a a body 4 speed.
case - c 99129 h
tail - 69128-3
anyone?
Re: Can anyone decode these trans numbers? [Re: BlakDak] #498952
10/16/09 08:22 PM
10/16/09 08:22 PM
BlakDak Offline OP
BlakDak  Offline OP
anyone?
Re: Can anyone decode these trans numbers? [Re: BlakDak] #498953
10/16/09 08:26 PM
10/16/09 08:26 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Casting numbers are pretty useless. Does it have a VIN pad on it? If so, what are all the numbers on it?
One shifter mounting point or two?
Re: Can anyone decode these trans numbers? [Re: Alaskan_TA] #498954
10/17/09 07:19 AM
10/17/09 07:19 AM
BlakDak Offline OP
BlakDak  Offline OP
its a short tail trans.
this is a email thing, as he is 200 miles away.
i am trying to make sure its not a early trans, or a OD unit.
I asked him for better pics, and numbers stamped into the trans, he came back with the casting numbers, and said he would have to borrow a camera.
the one pic he does have the trans is painted.
Re: Can anyone decode these trans numbers? [Re: BlakDak] #498955
10/18/09 08:50 AM
10/18/09 08:50 AM
laurens,south carolina
mopar_rr Offline
mopar_rr  Offline
Hi from what i have sean the od trans have a bigger bearing retainer on frount of trans.They take a different bell housing..5 5/16..hole opening..
HAVE A NICE MOPARIN DAY....
