Page 1 of 3 1 2 3
porting 906 heads #498891
10/16/09 05:51 PM
10/16/09 05:51 PM
mt.ephraim , new jersey
jsmopar1072 Offline OP
what are some of the do's and dont's on porting 906 heads? and could you post pics of your ported 906's?thanks jeff
i went from this
WINNING IS ALL LUCK,ASK ANY LOSER! OBJECTS IN MIRROR APPEAR TO BE LOSING! JEFF'S BUDGET DODGE GARAGE!!!!
Re: porting 906 heads [Re: jsmopar1072] #498892
10/16/09 05:55 PM
10/16/09 05:55 PM
to this
Re: porting 906 heads [Re: jsmopar1072] #498893
10/16/09 05:56 PM
10/16/09 05:56 PM
better pic
Re: porting 906 heads [Re: jsmopar1072] #498894
10/16/09 06:00 PM
10/16/09 06:00 PM
intake side
Re: porting 906 heads [Re: jsmopar1072] #498895
10/16/09 06:03 PM
10/16/09 06:03 PM
now
Re: porting 906 heads [Re: jsmopar1072] #498896
10/16/09 07:30 PM
10/16/09 07:30 PM
Andrews,In. U.S.of A.
67_Satellite Offline
Ex ports look pretty good as is. The pushrod pinch in the intake ports should be squared up and equalized to the widest point. Blend the lowest cut under the seat into the port without opening it up beyond 85% of the valve size.The short side turn is tricky to get right,be careful there even though there is much to be gained there. There was a very good article by Steve Dulcich in mopar muscle some years back,you might be able to find it online somewhere. It was a multi part article which covered the subject better than any magazine article since.Don't try to go crazy on size and you likely won't hurt anything too bad.
Re: porting 906 heads [Re: 67_Satellite] #498897
10/16/09 07:40 PM
10/16/09 07:40 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Re: porting 906 heads [Re: 67_Satellite] #498898
10/16/09 07:53 PM
10/16/09 07:53 PM
South Jersey
kruger Offline
Yours Too!
kruger  Offline
Yours Too!
South Jersey
Nice job.Lotsa work.I wish I had the patience.
Muscle Mopar artical on 906 heads.
Making The Most Of 906 Heads
http://www.moparmusclemagazine.com/techarticles/engine/mopp_0906_mopar_906_cylinder_heads/index.html
I've really got to learn to type faster forphorty
Re: porting 906 heads [Re: kruger] #498899
10/16/09 07:59 PM
10/16/09 07:59 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
Here's mine, they've been milled a little too...
Re: porting 906 heads [Re: sixpakdodge] #498900
10/16/09 08:23 PM
10/16/09 08:23 PM
how can i tell how much has been milled off of mine and what r the stock cc's
Re: porting 906 heads [Re: sixpakdodge] #498901
10/16/09 08:40 PM
10/16/09 08:40 PM
South Jersey
kruger Offline
Yours Too!
kruger  Offline
Yours Too!
South Jersey
Looking at sixpakdodges pic..and just guessing...looks like .060+ and matched on the intake side?
Compare his pic to yours at the lower runners.
Re: porting 906 heads [Re: jsmopar1072] #498902
10/16/09 08:40 PM
10/16/09 08:40 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Measure the head bolt boss under the exh ports , nominally they are 1.000 , TYPICAL chamber CC on untouched heads is 90cc .
becareful messing with the shot turn .
Re: porting 906 heads [Re: JohnRR] #498903
10/16/09 08:53 PM
10/16/09 08:53 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
My heads have been extensively ported and modified. They are now Max Wedge port size and closed chambered. I'm having a valve job done on them right now and will post specs when I get them back.
FWIW, these heads were done before I was born, lol!!!
Re: porting 906 heads [Re: sixpakdodge] #498904
10/16/09 09:14 PM
10/16/09 09:14 PM
Pennsylvania
proshiftcharger Offline
Pennsylvania
Just curious...
Are you guys still using templates to do the port work that DC & MP used to sell?? Or is there a better way now?? How many hours does it take to do a pair of 906's to the max as far as you can
take them??
Re: porting 906 heads [Re: proshiftcharger] #498905
10/16/09 09:16 PM
10/16/09 09:16 PM
i got six hours on one head and it looks like it might need some more time
Re: porting 906 heads [Re: proshiftcharger] #498906
10/16/09 09:52 PM
10/16/09 09:52 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Just curious...
take them??
Fully ported aluminum heads with valve job typically takes about 16-18 hours. Cast iron stockers take a bit more time due to the need to be careful not to break through. Much harder to fix cast iron. Also it takes more time to grind out.
Re: porting 906 heads [Re: dodgeboy11] #498907
10/16/09 10:42 PM
10/16/09 10:42 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Nice work. This is the only pic I have of my 906's on my 63. I bet I have about 30 hrs total in them as not only did I do the bowls and ports I enlarged the seats and installed the 2.14 & 1.81 valves myself. I really dont think I can ever port another set of heads as it made my back hurt so bad bending over to work on them I could hardly stand it. I think the next eng I build I will just get some CNC aluminum heads and save my back the pain. What is the car and combo they are going on?? Ron
Re: porting 906 heads [Re: jsmopar1072] #498908
10/17/09 12:12 AM
10/17/09 12:12 AM
Canada
CrAzYMoPaRGuY Offline
Canada
I found the short side radius is fairly close to the water jacket... LOL My buddy ported a set of 906s for his Charger, the car had water out one bank, took it apart and found a hairline crack on the short side radius.
I like bowl work for a street car, don't use 1.88 exhaust valves, go 2.14 and 1.81 to get the seats up, make sure the guides are good, a decent multi angle grind and basic porting for "common sense" flow and I think all is good...
CrAzYMoPaRGuY
Re: porting 906 heads [Re: 383man] #498909
10/17/09 12:13 AM
10/17/09 12:13 AM
Canada
Canada
I shoulda read the thread first, you are bang on IMO...
CrAzYMoPaRGuY
Re: porting 906 heads [Re: CrAzYMoPaRGuY] #498910
10/17/09 08:48 AM
10/17/09 08:48 AM
its a 72 charger 727 3800 stall 3:91 ratio 8 3/4.
440
4.350 bore
3.75 stroke
diamond flat tops sitting flush
heads are 906's ported
2.14 int 1.81 exh valves cut .040 1.6 ratio roller rockers
cam in ex
gross lift .646 .630
duration@.050 264 .275
112.0 separation
solid roller
Page 1 of 3 1 2 3
