Max Wedge trunk battery hold downs #498455
10/16/09 09:21 AM
10/16/09 09:21 AM
MS
redex79 Offline OP
redex79  Offline OP
MS
How did the factory attach the rear battery hold down bolts to the trunk floor pan on factory Max Wedge cars ? Pictures would be good.
Truckin Weekend !
70 Dodge Dart Swinger
11 Ram 1500 Laramie 4x4
21 Dodge Durango GT
Re: Max Wedge trunk battery hold downs [Re: redex79] #498456
10/16/09 08:04 PM
10/16/09 08:04 PM
MN
ryangtogtx Offline
ryangtogtx  Offline
MN
Re: Max Wedge trunk battery hold downs [Re: ryangtogtx] #498457
10/16/09 08:29 PM
10/16/09 08:29 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
there is are two mounts welded to the floor pan with a hole in each (lookls similar to the rear seat mount but with a hole not a slot)then a j-bolt goes into them
Re: Max Wedge trunk battery hold downs [Re: prochargedhemi] #498458
10/19/09 09:07 AM
10/19/09 09:07 AM
MS
redex79 Offline OP
redex79  Offline OP
MS
Is it sheet metal folded together and bent in a ( T ) or an angle?
Truckin Weekend !
21 Dodge Durango GT
