Idle problems! #498445
10/16/09 09:16 AM
10/16/09 09:16 AM
east coast
Otherlane Offline OP
east coast
I have a sdss built motor and a prosystems carb.i will call patrick today but want to see what everyone else thought.if I start my car up I have to hit the gas to keep it running than after a min or two its idles fine.than if I turn the rpms up to about 2000 to 2500 it doesn't want to idle back down..i have not touch anything on either the engine or the carb since the dyno.i did put a new carb to intake gasket on it thinking there's a vacum leak.does anyone have any ideas on whats not making the idle go back down
Re: Idle problems! [Re: Otherlane] #498446
10/16/09 09:25 AM
10/16/09 09:25 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
you using vacuum advance??
A lot more details would be nice. did not keep up my Clairvoyant's membership.
Re: Idle problems! [Re: Dodgem] #498447
10/16/09 10:14 AM
10/16/09 10:14 AM
east coast
east coast
nope all out drag motor
Re: Idle problems! [Re: Otherlane] #498448
10/16/09 10:43 AM
10/16/09 10:43 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
A vac leak would be a good starting point, then timing
Re: Idle problems! [Re: Otherlane] #498449
10/16/09 01:46 PM
10/16/09 01:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Did you get a vacuum reading while on the dyno... put
a vac gauge on it and see if its the same... if you
havent touched anything else the timing SHOULD be right
Re: Idle problems! [Re: Otherlane] #498450
10/16/09 01:59 PM
10/16/09 01:59 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
did you check the linkage by hand to be sure it was not sticking?and after turning up the idle to 2k/2500rpm and back down?
Re: Idle problems! [Re: blownzoom440] #498451
10/16/09 02:34 PM
10/16/09 02:34 PM
Hemiroid Offline
Hemiroid  Offline
Could have too light of a spring in the dist., or it fell off
Re: Idle problems! [Re: Hemiroid] #498452
10/16/09 03:10 PM
10/16/09 03:10 PM
east coast
east coast
I haven't touch anything since the dyno.i don't know if a vacunm gauge was used at the dyno.if I give it gas to about 2-2500 than get off the gas it was to still in that rpm.oh my distibutor is locked.does anyone think the cab?i will check the linkage also and give intake bolt a small turn of the wrench
Re: Idle problems! [Re: Hemiroid] #498453
10/16/09 03:12 PM
10/16/09 03:12 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
I'd start by disassembling the carb & cleaning everything W/ carb cleaner/Brake Kleen & blowing compressed air through all passages, air bleeds etc. Dyno was long while ago, & carbs don't like sitting for a year W/ out being used.
Re: Idle problems! [Re: RyanJ] #498454
10/16/09 03:46 PM
10/16/09 03:46 PM
east coast
east coast
I will go though the carb.
