Steel roller rockers for Stage VI? #498410
10/16/09 07:02 AM
10/16/09 07:02 AM
Down under
slantman Offline OP
slantman  Offline OP
Down under
Does anybody know of any steel roller rockers with offset intake to suit Stage VI heads (0.45" offset)?
I know I can get aluminium rockers, such as HS, but would prefer steel for street use with a solid roller cam.
Re: Steel roller rockers for Stage VI? [Re: slantman] #498411
10/16/09 08:44 AM
10/16/09 08:44 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Stage 6's use a std offset rocker , what's your spring pressure? There are only 2 steel roller tip rockers that are any good , Comp pro magnums and RAS , I think the RAS is a bushed rocker .
Re: Steel roller rockers for Stage VI? [Re: JohnRR] #498412
10/16/09 09:10 AM
10/16/09 09:10 AM
Down under
slantman Offline OP
slantman  Offline OP
Down under
From memory, the spring pressure is 200# on the seat and 500# on the nose.
I'm not actually using Stage 6 heads, I have a set of 518M heads that have been modified and require offset intake rockers. An offset of either 0.450" or 0.485"should work on these heads. I was lead to believe that the Stage 6 heads used a 0.450" offset intake.
Re: Steel roller rockers for Stage VI? [Re: JohnRR] #498413
10/16/09 09:11 AM
10/16/09 09:11 AM
i'm pretty sure the stage 6 uses a .450 offset intake rocker.
Re: Steel roller rockers for Stage VI? #498414
10/16/09 10:51 AM
10/16/09 10:51 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Depends on the version of Stage VI. The standard-port version(s) use a standard-offset intake & exhaust; the MW version needs the .485" intake offset.
If the heads in question use standard-offset rockers, the best bet IMO is the RAS stainless-steel setup. Not cheap, but basically bullet-proof for that configuration.
