stupid shifter pad bolts (4 speed)what the heck???
#498140
10/15/09 05:52 PM
10/15/09 05:52 PM
Posts: 8,858 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
iv been trying to get 2 bolts(i got the 3rd one) out that mounts the shifter pad to the side of the 4 speed trans thay are counter sunk and cone shaped so it cant really get anything like wd or anything like that to the threads(iv tried) i took a lil bottle torch and got the bolt as hot as i could(as hot as it was gonna get) and hit the bolts with a punch bunch of times to try to break it loose no luck all im doing is twisting the allen wrench and when i quit it started to strip the allen hole soooo what if i took a sledge hammer to the alum pad and tried to break the pad off around the bolts(i dont need the pad) or will i break the tail shaft housing? i dont have a cutting torch and there is no way to get any kind of penatrating fluid to the threads i think if i used a easy out it will snap off so what the heck???? the one bolt i got out you can see lil dab of blue locktite on the threads did the factory do that? anyone else have this problem?? ralph ![](/ubbthreads/images/graemlins/shout.gif) besides making up new bad words(i already know all the old bad words) has not been good day ![](/ubbthreads/images/graemlins/maad.gif) ralph
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: stupid shifter pad bolts (4 speed)what the heck???
[Re: toplescuda]
#498141
10/15/09 05:58 PM
10/15/09 05:58 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
If you have an iar chisel you can dig it into the face of the bolt and chisel it around counter clockwise. Iv'e had that happen to me before. If you dont have an iar chisel, A hand chisel will break it loose.
Founder and CEO of the Central Valley Mopar Drag Pack
[Re: toplescuda]
#498142
10/15/09 05:58 PM
10/15/09 05:58 PM
Posts: 12,245 Looking for a way out of Middl...
IMGTX
Tranny in the car or out? You may be able to lower the tranny enough to drill the heads out and then remove the left over stud with Vise Gripes. I had good luck with one of those hand held hammer impact tools and a good solid allen tip. (this guy http://www.kk.org/cooltools/archives/000723.php ) Good news is if you get one more you may be able to hammer plate and rotate it to help remove the third. I would be cautious trying to break the plate. The tail is cast and will be brittle. No matter how much you think the cast iron will NOT break before the aluminum plate this will be the time it does.
[Re: Jim_Lusk]
#498145
10/15/09 06:48 PM
10/15/09 06:48 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
the trans is out of the car and the bolts are countersunk pretty deep no way of welding anything to the bolt head or cutting a slot into the head with the plate in the way that is also the reason wd40(or anything else) wont get to the threads
[Re: toplescuda]
#498146
10/15/09 07:40 PM
10/15/09 07:40 PM
Posts: 26,011 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I can't count the number of those I've had to drill out.
[Re: toplescuda]
#498147
10/15/09 07:43 PM
10/15/09 07:43 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
If you don't have an impact that you can use with the allen wrench then weld a nut to the screw. I know it's countersunk and tight. That's why I suggest a nut. You can weld the inside of the nut to the screw. It deosn't have to be a hold-together-forever weld. You'll never get the tip of the gun in the nut but you can stick the wire out a little more than usual.
[Re: JohnRR]
#498150
10/16/09 01:43 AM
10/16/09 01:43 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
I think I used Aero Kroil or PB blaster and let it sit for a few days and repeated... They were a problem....I was very happy when I got them out. The alum plate is repoped but costs a few bucks.. maybe try a slightly larger metric allen wrench and hammer it into the head a bit... Or just drill the head off the bolt and save the alum plate... ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Dennis_K]
#498152
10/17/09 07:46 PM
10/17/09 07:46 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
i got a easyout today but i havent tried it yet
[Re: sthemi]
#498154
10/18/09 01:12 PM
10/18/09 01:12 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
This is exactly how I have got them out in the past. If you can schock the bolt enough it will break free and it also helps with the allen head staying in there while turning it out... ![](/ubbthreads/images/graemlins/Twocents.gif)
