valves for indy sr,s #498113
10/15/09 05:15 PM
10/15/09 05:15 PM
Virginia Beach, VA
O
Old School Offline OP
O
Virginia Beach, VA
i keep wearing out the intake valves in my sr,s. they are the ones supplied with the heads.is there a better longer lasting valve for these heads? they are 2.19". where would i get them?
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: valves for indy sr,s [Re: Old School] #498114
10/15/09 05:20 PM
10/15/09 05:20 PM
Manley has them---call Marsh Performance 336 752 2879 for your best deal
Re: valves for indy sr,s [Re: ] #498115
10/15/09 05:31 PM
10/15/09 05:31 PM
Virginia Beach, VA
O
O
Virginia Beach, VA
what do i ask for,there best?
Re: valves for indy sr,s [Re: Old School] #498116
10/15/09 05:46 PM
10/15/09 05:46 PM
SoCal
Brian Hafliger Offline
SoCal
I use Ferrea. They flow better and I think they are better quality.
Just ask for the Indy replacement valves and they'll be right.
Brian Hafliger
Re: valves for indy sr,s [Re: Brian Hafliger] #498117
10/15/09 05:52 PM
10/15/09 05:52 PM
Virginia Beach, VA
O
O
Virginia Beach, VA
wheres the best place to get them? also,is it worth it to go up to 2.25"? its on a :
500"
13.4 cr
272/276 .750" solid roller.
sr 295 cnc
about how much more cfm?
Re: valves for indy sr,s [Re: Old School] #498118
10/15/09 09:46 PM
10/15/09 09:46 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
500"
13.4 cr
sr 295 cnc
First, what's wearing out on the valves? The stems, the tip or is the head tuliping? What kind of seals are you running on there and how much guide clearance do you have? I think it's worth going to the larger valve, provided there's some portwork to go along with blending in the larger valve job. Average CFM increase? That I can't tell you but I did get a set of Perf RPM heads to flow 345 with a 2.250 valve and a max wedge port. So I can only imagine how much better the SR's would respond to it.
Re: valves for indy sr,s [Re: dodgeboy11] #498119
10/15/09 10:31 PM
10/15/09 10:31 PM
care to share a picture of that?
Re: valves for indy sr,s [Re: dodgeboy11] #498120
10/15/09 11:49 PM
10/15/09 11:49 PM
Virginia Beach, VA
O
O
Virginia Beach, VA
it is the stems that keep wearing out.i use the viton seal.
i thought i read a post awhile ago from dwayne porter about having to do something about the guides in theese heads.
Re: valves for indy sr,s [Re: Old School] #498121
10/16/09 12:32 AM
10/16/09 12:32 AM
AndyF Offline
AndyF  Offline
It is just a standard plus size Chevy big block valve so you can find them from most everyone.
Re: valves for indy sr,s [Re: Old School] #498122
10/16/09 03:16 AM
10/16/09 03:16 AM
San Diego, CA
brktracr Offline
super street
brktracr  Offline
super street
San Diego, CA
I second the Ferrea, Brian put them in my SR's and I've been extremely happy with the heads and the work he did on them.
1.298 60 ft 6.001 1/8 mile 114 mph 9.52 1/4 mile 140.87 mph @ 3110 lbs
Re: valves for indy sr,s [Re: brktracr] #498123
10/16/09 08:01 AM
10/16/09 08:01 AM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
I,ve run the sr heads with no excessive stem wear in 8 years.Granted i run a small cam(.620),maybe you have some kind of geometry problem.
Randy Brough 1967 440 Dart S/P 6.37 106mph best eighth 3150 lbs
Re: valves for indy sr,s [Re: moparmxz] #498124
10/16/09 01:06 PM
10/16/09 01:06 PM
Virginia Beach, VA
O
O
Virginia Beach, VA
my cam is a .661 solid roller.i use indys 1.6 rocker arm kit with a roller tip.the pushrods are the right length.i have this exact combo on three motors.all of them wear the stems to fast.
im rebuilding one now and im trying some 1.7 t&d,s.if that fixes it,i will swap the others over too.
Re: valves for indy sr,s [Re: ] #498125
10/16/09 01:30 PM
10/16/09 01:30 PM
Virginia Beach, VA
O
O
Virginia Beach, VA
ordered them today.you were right,awesome deal,i mentioned your username,thanks
Re: valves for indy sr,s [Re: Old School] #498126
10/16/09 03:19 PM
10/16/09 03:19 PM
Life ain't as complicated as folks make it out to be
and Andy is right--Chevy .100 long and there ya go from anywhere--I think DairyMart has those but the Manleys from Todd will do the trick-- and I bet cheaper than Ferrera which are good too.
