Re: Adjustable pushrods
[Re: Dodgem]
#497833
10/15/09 12:43 PM
10/15/09 12:43 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Fairly good deal if you want to use them. IMO I would buy one for measuring preload to see what I need to cut the build your own at. They will probably be ok with light springs but the adjuster bolt that screws into the center of the push rod is pretty dang wimpy to take much spring pressure. Seems to me there is enough push rod/rocker arm problems with out loking for it.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: Dodgem]
#497835
10/15/09 10:46 PM
10/15/09 10:46 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I used them on my 509/292 back in the day then on the 533/320 mp cams worded great much more rpms!
How would you get more RPM with a heavier push rod (unless you turned it into a solid lifter). I've never been a fan of them... they add weight to a system that sure doesnt need any extra weight.... JMO ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#497836
10/16/09 12:45 AM
10/16/09 12:45 AM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
More rpm is what they are made for.... to reduce(or better put) ELIMINATE lifter pump up. Unfortunately these ones are for converting to hydr rockers on a solid cam.
[Re: RemCharger]
#497837
10/16/09 12:47 AM
10/16/09 12:47 AM
Posts: 75,112 A Banana Republic near you.
JohnRR
wouldn't the CORRECT LENGTH pushrood do the same thing ?
To me they are a pisspoor bandaid for pisspoor valve seat machining on a rebuild ...
[Re: JohnRR]
#497838
10/16/09 01:06 AM
10/16/09 01:06 AM
RemCharger
Sk. Canada
True. But were not talking about prostock motors here. I used them on my street 383 so that each and every valve was adjust to the spec of .002 preload, AND , when everything wears a bit, they can be readjusted. I have the comp pro magnum lifters. ![](/ubbthreads/images/graemlins/drive.gif)
[Re: RemCharger]
#497839
10/16/09 08:45 AM
10/16/09 08:45 AM
JohnRR
uuuummmm , wouldn't an adjustable rocker do the same thing ???
[Re: JohnRR]
#497840
10/16/09 10:29 AM
10/16/09 10:29 AM
RemCharger
Sk. Canada
Yes. And if I had lots of money to burn, thats what I would've done. But this setup works well, so I can't complain.
