Does this take the place of a PCV valve?
#497466
10/14/09 10:28 PM
10/14/09 10:28 PM
Posts: 733 Nampa, ID
MadMatt
Nampa, ID
I've read several threads on here about the need for a PCV setup, with PCV in one valve cover and a breather in the other. Just wondering, does anyone know if this setup will accomplish the same purpose? Milodon doesn't actually refer to it as a PCV, but seems it would work. http://www.summitracing.com/parts/MIL-85682/?image=large
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Does this take the place of a PCV valve?
[Re: MadMatt]
#497469
10/15/09 12:00 AM
10/15/09 12:00 AM
RapidRobert
It would work if you connected that nipple with a hose to the header collector with a fitting welded into the collector at a 45 angle & it's shaped like a hypodermic needle & the exhaust flowing past it draws fumes out doing the same function as the PCV does. Supposedly in a street car there is not enough velocity for this to work well as it does in a race only eng. It will add unburned hydrocarbons to the tailpipe emissions but it does eliminate the controlled vacuum leak of the pcv into the intake tract.
[Re: MadMatt]
#497470
10/16/09 10:24 AM
10/16/09 10:24 AM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
Another thing to consider is that PCV valves have different metered amounts of airflow for specific applications. The metering is pretty close from valve to valve, however I noticed this on my /6, when I used a V8 valve I had lying around. It flowed too much air for my little slanty. Once I used the correct vavle and it idled and ran beter off idle with out the flutter at the PCV valve.
This breather you're referring to has no metering what so ever. It just attaches the hose to the valve cover and runs the air through an internal sponge or something to separate the oil mist....No?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#497471
10/16/09 12:29 PM
10/16/09 12:29 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
It's a BREATHER , air goes thru it into the engine when the PCV is doing it's job .
[Re: MadMatt]
#497472
10/16/09 01:12 PM
10/16/09 01:12 PM
Posts: 12,248 Looking for a way out of Middl...
IMGTX
Here is What I used. They are available at Autozone and are chrome. They have a hole in the top for a PCV valve and no breather holes on the underside. Use one of these in one valve cover and a regular breather on the other valve cover. All you have to do is get a grommet to adapt your PCV to this and your good to go. The grommets are also available from just about any parts store. Technically is this a breather or an adapter? ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: MadMatt]
#497473
10/16/09 03:13 PM
10/16/09 03:13 PM
PCV-> Positive Crankcase Ventilation as long as outside air gets circulated through the crankcase, the engine dosn't care how its done. Either by a PCV, dumps into the header collectors, or what the OP shown. Personally I don't like PCV's or the oil mist that gets drawn through the intake and burned.
[Re: stumpy]
#497475
10/16/09 04:24 PM
10/16/09 04:24 PM
POSITIVE (high) pressure in the crankcase yes I know that. Intake manifold, exaust, or the ATMOSPHERE act as NEGITIVE (low) pressure until it equalizes with the crankcase. then its neutral. remember, high pressure always seek low pressure. dosn't care how it get there, as long as it does.
[Re: stumpy]
#497477
10/16/09 04:47 PM
10/16/09 04:47 PM
Atmosphere dosn't need to supply a flow. just an escape. IF the atmosphere(14.1psi) is of a lower PSI then whats in the crankcase say, 14.2psi+, thats (atmosphere) negitive pressure. Same principle as when you deflate a tire.
[Re: stumpy]
#497479
10/16/09 05:23 PM
10/16/09 05:23 PM
whatever you win. end communication.
